Building project - Eclipse
Mon Mar 12 15:53:45 UTC 2012
On 03/12/2012 04:25 PM, Gedare Bloom wrote:
> On Mon, Mar 12, 2012 at 10:04 AM, Binkowski, Cassio<cassioiks at gmail.com>  wrote:
>> I have been trying to build a test project in eclipse but have neen unable
>> to do so.
>> The configuration I've been using are the following:
>> Base path: /opt/rtems-4.11
>> BSP pah: /home/rtems/test/sparc-rtems4.11
>> It is giving me this:
>> make invokation `make PROJECT_RELEASE=/home/rtems/test/sparc-rtems4.11'
>> returned with error status 2
>> And Eclipse is returning the following, when trying to build:
>> **** Build of configuration RTEMS Executable Configuration for project test
>> make all
>> Building file: ../init.c
>> Invoking: RTEMS C Compiler
>> /opt/rtems-4.11/bin/gcc -Os -g -Wall -c -fmessage-length=0 -pipe -MMD -MP
>> -MF"init.d" -MT"init.d" -o "init.o" "../init.c"
>> /bin/sh: /opt/rtems-4.11/bin/gcc: No such file or directory
> Probably this should be looking for /opt/rtems-4.11/bin/sparc-rtems4.11-gcc
No, this shows only that the BSP path is wrong.
Did you build and install a BSP?
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
