question about rtems compiler
Luca Cinquepalmi cinquepalmi at planetek.it
Wed May 9 12:10:46 UTC 2012
I have no error... I'd just like to know the difference bewtween a
simple C source code (with main function)
and rtems structured one... thanks.
Il 09/05/2012 13.41, Wendell Silva ha scritto:
> Luca,
> What kind of erros?
> Can you post the error message, please?
> I suppose you are not using the -B command line option properly, which
> yelds linker error.
> --Wendell.
> 2012/5/9 Luca Cinquepalmi <cinquepalmi at planetek.it
> <mailto:cinquepalmi at planetek.it>>
>     Can anybody explain me why rtems gcc compiler doesn't compile a
>     simple C source
>     code with main? I need to adopt a rtems structured code to compile
>     it... How does compiler
>     understand where to start? Is the main funcion included in some
>     rtems macros?
>     thanks a lot
>        Luca
>     _______________________________________________
>     rtems-users mailing list
>     rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     http://www.rtems.org/mailman/listinfo/rtems-users
URL: <http://lists.rtems.org/pipermail/users/attachments/20120509/6b87c674/attachment-0001.html>
