ANN: rtems-4.10 toolchain rpms available for openSUSE-12.2
Ralf Corsepius ralf.corsepius at rtems.org
Thu Sep 20 12:25:06 UTC 2012
Hi,
I am proud to announce the availability of openSUSE-12.2 toolchain rpm
packages and repositories for RTEMS-4.10.
ftp://ftp.rtems.org/pub/rtems/linux/4.10/suse/12.2/
Except of having reflected system particularities of openSUSE-12.2 back
to the rpm-specs, the actual toolchain sources are mostly identical[1]
to those so far having been used for other Linux distros and older
openSUSE releases.
Ralf
[1] There is one exception: rtems-4.10-bfin-rtems4.10-gdb(-4.7.3) had
failed to build from source on openSUSE. When investigating, the cause
had shown to be a general issue related to the linux kernel on several
more distros (Comprising all Fedoras).
