rtems_chain_get_first and rtems_chain_node_is_off_chain
Wendell Silva silvawp at gmail.com
Sat Apr 13 02:09:40 UTC 2013
Hi,
Let chain C, already initialized with N nodes, N > 0.
rtems_chain_node* node = rtems_chain_get_first(&C);
According to the documentation of rtems_chain_get_first, the node is
REMOVED from the chain.
But, node doest not pass the test of being removed (or extracted) in
rtems_chain_node_is_off_chain.
So, rtems_chain_node_is_off_chain(node) returns false. But it should return
true.
Inspecting the node, I noticed that node->next and node->previous aren't
NULL as expected for a node that was extracted from a chain.
Conclusion: unless the term REMOVED is not the same as EXTRACTED, probably
this is a bug in rtems_chain_get_first;
Please, educate me if I'm wrong.
--Wendell.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130412/d0a26a79/attachment.html>
