Effect of additionnal save/restore instructions
Leonard Bise leonard.bise at syderal.ch
Tue Apr 23 09:02:43 UTC 2013
Hello all,
I'm having a problem regarding the processor window registers that I cannot
explain easily mostly because I'm not super familiar with this subject.
First, I'm using a LEON2 Sparc v8 processor and RTEMS 4.8 version which is
required by our project.
We have a function using inline assembly to perform a flat delay, here is
the code it use.
void SCET_wait_2us(void) {
        /*#[ operation SCET_wait_2us() */
        /* Performs a 60us delay using an ASM loop, this piece of code has
been
         * measured on HW to validate the duration is correct */
        __asm__("                                \
                save;                            \
                set " XSTR(NB_ITER_60US) ", %l7; \
                StartLoop1us:                    \
                dec 1, %l7;                      \
                cmp %l7, 0;                      \
                bne StartLoop1us;                \
                nop;                             \
                restore;                         \
Originally this code didn't have the save and restore instruction but our
sub contractor added them because they had problems compiling. I find it an
odd solution but whatever.
Once this code was implemented we started seeing random processor
reset occurring in various contexts.
I tested this code while being in the Eclipse debugger and once the crash
happened I noticed I had a segmentation fault in Eclipse. I used GRMON to
check the processor register and noticed that the last trap that occurred
was a window underflow trap 0x06.
I found in the RTEMS sources the code for this handler, and while I haven't
understood everything I took out that the code was trying to recover from
this error, is this correct?
I copied the trap handler code below.
RTEMS 4.8 branch
file : rtems / c / src / lib / libcpu / sparc / reg_win / window.S
SYM(window_underflow_trap_handler):
         * Calculate new WIM by "rotating" the valid bits in the WIM left
         * by one position. The following shows how the bits move for a
SPARC
         * cpu implementation where SPARC_NUMBER_OF_REGISTER_WINDOWS is 8.
         * OLD WIM = 76543210
         * NEW WIM = 07654321
         * NOTE: New WIM must be stored in a global register since the
         * "save" instruction just prior to the load of the wim
         * register will result in the local register set changing.
        mov %wim, %l3 ! Calculate new WIM
        sll %l3, 1, %l4 ! l4 = WIM << 1
        srl %l3, SPARC_NUMBER_OF_REGISTER_WINDOWS-1, %l5
                                        ! l5 = WIM >> (Number Windows-1)
        or %l5, %l4, %l5 ! l5 = (WIM << 1) |
                                        ! (WIM >> (Number Windows-1))
        mov %l5, %wim ! load the new WIM
        nop; nop; nop
        restore ! Two restores to get into the
        restore ! window to restore
        ldd [%sp + 0x00], %l0 ! First the local register set
        ldd [%sp + 0x08], %l2
        ldd [%sp + 0x10], %l4
        ldd [%sp + 0x18], %l6
        ldd [%sp + 0x20], %i0 ! Then the input registers
        ldd [%sp + 0x28], %i2
        ldd [%sp + 0x30], %i4
        ldd [%sp + 0x38], %i6
        save ! Get back to the trap window.
        save
        jmp %l1 ! Re-execute restore.
        rett %l2
>From my understanding this code should not ever fail, is that correct?
What I'm not sure is that if this type of trap can be a
common occurrence or if that means something went bad in the software.
Basically now I removed the save/restore and it seems to be working fine
but I'll have to explain exactly what was happening before.
Is the compiler not expecting the user to add save/restore and could that
lead to the behavior we see sometimes (processor reset). What are the usual
way to handle this type of inline assembly? Never use save/restore?
Also our customer gave us a sequence of command to send to the software
that would produce this reset systematically however when we got the
equipment over here, I tried with the same code the sequence and it is not
happening as often as they say. There seem to be a lot of randomness to
this problem.
I really hope someone can provide some knowledge on this type of issue.
*Léonard Bise*
Software Design Engineer
Direct Line +41 (0)32 338 9902
*SYDERAL SA*
Neuenburgstrasse 7
CH-3238 Gals (Switzerland)
Desk Line +41 (0)32 338 9800
Web Site http://www.syderal.ch
URL: <http://lists.rtems.org/pipermail/users/attachments/20130423/82edc457/attachment.html>
