Mingw autoconf 2.69 package
Matthew J Fletcher amimjf at gmail.com
Wed Apr 3 14:33:34 UTC 2013
Hi,
>I always build the Autotools from source in MinGW/MSYS.  You have to make
sure, that >your M4 is reasonably up to date (I use M4 1.4.7).
M4 1.4.14 here.
>A "./bootstrap" doesn't work for me.  I use "./bootstrap -g".
Same issue about Perl include paths, i think i've managed to not 'install'
the pre-built autoconf correctly.
On 3 April 2013 15:24, Sebastian Huber
<sebastian.huber at embedded-brains.de>wrote:
> On 04/03/2013 04:15 PM, Matthew J Fletcher wrote:
>> I've been attempting to build git head (4.11) on mingw but i am having a
>> bit of
>> problem installing the updated autoconf package available here.
>> ftp://ftp.rtems.org/pub/rtems/**mingw64/4.11/i686/rtems-4.11-**autoconf/<ftp://ftp.rtems.org/pub/rtems/mingw64/4.11/i686/rtems-4.11-autoconf/>
>> <ftp://ftp.rtems.org/pub/**rtems/mingw64/4.11/i686/rtems-**4.11-autoconf/<ftp://ftp.rtems.org/pub/rtems/mingw64/4.11/i686/rtems-4.11-autoconf/>
>> I am a bit of a mingw newbe do i just extract and copy over the new files
>> I tried this in two steps;
>> 1) overwrite the /opt/rtems-4.11/  'bin' and 'share' directories with
>> files
>> from autoconf 2.69
>> 2) because there was a autoconfig (and auto* in /bin) renamed those with
>> _ in
>> front of them.
>> autoconf --version now gives 2.69, yay !
>> Alas doing a bootstrap gives.
>> -------------- snip -------------------
>> $ ./bootstrap
> sure, that your M4 is reasonably up to date (I use M4 1.4.7).
> E-Mail  : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-users mailing list
> rtems-users at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-users<http://www.rtems.org/mailman/listinfo/rtems-users>
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130403/20c1a186/attachment-0001.html>
