buf == NULL in BSP_uart_termios_write_com() when compiled on a FreeBSD host
Nick Withers nick.withers at anu.edu.au
Mon Jun 24 07:16:09 UTC 2013
Hullo again RTEMSers!
I'm running into an assertion failure in RTEMS (Git HEAD, brought up to
date today) running sample apps on the MVME3100 (as well as my own one,
such that it currently is!) compiled on a FreeBSD 9.1-STABLE (r252020)
machine.
I've had no such problems with the binaries produced on a Ubuntu 12.04
box (and loading 'em from the FreeBSD machine's TFTP server works fine).
In both cases, everything's compiled from source (including tools),
following http://wiki.rtems.org/wiki/index.php/Quick_Start and
http://wiki.rtems.org/wiki/index.php/Building_Tools . I've run through
the procedure a couple o' times and tried using Bash as the shell during
the build (instead of tcsh) to no avail.
Here's the complete serial output booting the MVME and trying to run
ticker.ralf:
____
> Copyright Motorola Inc. 1999-2005, All Rights Reserved
> MOTLoad RTOS Version 2.0,  PAL Version 1.1 RM03
> Wed Oct 19 17:29:08 MST 2005
> MPU-Type             =MPC8540
> MPU-Int Clock Speed  =666MHz
> MPU-CCB Clock Speed  =333MHz
> MPU-DDR Clock Speed  =166MHz
> MPU-PCI Clock Speed  =66MHz, PCI, 64-bit
> MPU-Int Cache(L2) Enabled, 256KB, L2CTL =A8000300
> Reset/Boot Vector    =Flash0
> Local Memory Found   =10000000 (&268435456)
> User Download Buffer =014D3000:016D2FFF
> MVME3100> tftpGet -c150.203.19.212 -s150.203.19.211 -fticker.ralf
> Network Loading from: /dev/enet0
> Loading File: ticker.ralf
> Load Address: 014D3000
> Download Buffer Size = 00200000
> Client IP Address      = 150.203.19.212
> Server IP Address      = 150.203.19.211
> Gateway IP Address     = 150.203.19.253
> Subnet IP Address Mask = 255.255.255.0
> Network File Load in Progress...
> Bytes Received =&248436, Bytes Loaded =&248436
> Bytes/Second   =&248436, Elapsed Time =1 Second(s)
> MVME3100> go
> Welcome to rtems-4.10.99.0(PowerPC/Generic (no FPU)/mvme3100)
> BSP: mvme3100, CVS Release ($Name$)
> CPU 0x8020 - rev 0x20
> Additionnal boot options are H
> Initial system stack at 3FDD8
> Software IRQ stack starts at 3FEC0 with size 16384
> Going to start PCI buses scanning and initialization
> Board Type: MVME3100-1152 (S/N E01230A)
> External (=PCI Bus) Clock Freq   :   66666666 Hz
> Core Complex Bus (CCB) Clock Freq:  333333330 Hz
> CPU Clock Freq:                     133333332 Hz
> Ethernet 0                  00:01:AF:30:54:3D
> Ethernet 1                  00:01:AF:30:54:3E
> Ethernet 2                  00:01:AF:30:54:3F
> Number of PCI buses found is : 2
> BUS:SLOT:FUN  VENDOR-DEV_ID: COMMAND STATUS BASE_ADDR0 BASE_ADDR1 IRQ_PIN -> IRQ_LINE
>   0:0x00:0    0x1057-0x0008:  0x0006 0x20B0 0x80000000 0x00000000       0 ->   0 (=0x00)
>   0:0x11:0    0x10E3-0x0148:  0x0146 0x02B0 0x80100004 0x00000000       1 ->   0 (=0x00)
>   0:0x12:0    0x10B5-0x6520:  0x0147 0x02B0 0x00000000 0x00000000       0 ->   0 (=0x00)
>   0:0x14:0    0x8086-0x3200:  0x0145 0x02B0 0x00011001 0x00012001       1 ->   2 (=0x02)
> Memory:                             268435456 bytes
> Cleared PCI errors: pci_stat was 0x20B0
> OpenPIC Version 1.2 (1 CPUs and 56 IRQ sources) at 0xE1040000
> OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 0
> OpenPIC timer frequency is 41666666 Hz
> MSR is 0x00001000, TCR 0x04000000
> Exit from bspstart
> Tundra Tsi148 PCI-VME bridge detected at 0x80100000, IRQ 0
> Tsi148 Outbound Ports:
> Port  VME-Addr   Size       PCI-Adrs   Mode:
> 0:    0x20000000 0x0E000000 0xC0000000 A32, SUP, D32, SCT
> 1:    0x00000000 0x00FF0000 0xCF000000 A24, SUP, D32, SCT
> 2:    0x00000000 0x00010000 0xCFFF0000 A16, SUP, D32, SCT
> 7:    0x00000000 0x01000000 0xCE000000 CSR, SUP, D32, SCT
> Tsi148 Inbound Ports:
> 0:    0xC0000000 0x10000000 0x00000000 A32, PGM, DAT, SUP, USR, MBLT, BLT
> vmeTsi148 IRQ manager: looking for registers on VME...
> Trying to find CSR on VME...
> vmeTsi148 - IRQ manager using VME CSR to flush FIFO
> libi2c: Claiming driver slot failed (rtems status code 5)
> Initializing I2C library failed
> Registering /dev/console as minor 0 (==/dev/ttyS0)
> assertion "buf != NULL" failed: file "../../../../../../../../../rtems/c/src/lib/libbsp/powerpc/mvme3100/../../powerpc/shared/console/uart.c", line 574, function: BSP_uart_termios_write_com
____
I ran my own code, with a fatal exception handler configured and a
CPU_Stack_Trace(). The addresses it spits out seem to be offset somewhat
(I tried subtracting up to 16 bytes off the e.g., the 0x100C8 address
and that didn't seem to work well), so I've used a combination of
powerpc-rtems4.11-addr2line and "powerpc-rtems4.11-nm -n" to arrive at
the following (which I hope is correct! I'm not really up-to-scratch on
these tools, I'm afraid...) for call history:
____
0x00018B94 - CPU_print_stack()
0x00003A3C - fatal_extension() [in my code]
0x0004BA28 - _User_extensions_Iterate()
0x00048D8C - _Internal_error_Occurred()
0x00047624 - rtems_fatal()
0x000248B8 - __assert_func()
0x000100C8 - BSP_uart_termios_write_com()
0x000283EC - rtems_termios_refill_transmitter()
0x0001027C - BSP_uart_termios_isr_com()
0x00019488 - C_dispatch_irq_handler()
0x000125B4 - ppc_exc_wrap_async_normal()
____
(Any tips for getting a better trace appreciated!)
Anyone got any suggestions? Hopefully I just did something simple and
dumb! :-P
Also, I should probably not be using Git HEAD...? Might start building
up 4.10.2 just to check, at least.
Cheers again for your time!
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
