Stack usage of ISR callstacks like rtems_clock_tick()
Matthew J Fletcher amimjf at gmail.com
Fri Mar 1 19:32:02 UTC 2013
Hi,
Has the stack usage of rtems_clock_tick() ever been (roughly) computed at
the maximum depth of the callstack ? the BSP's seem to vary quite a bit
from 1k to 4k for the interrupt stacks.
A while back i used stackcheck.pl by Dan Kegel,
http://www.kegel.com/stackcheck/ it gives you the stack usage of each
function, but it would still be quite a bit of effort to add them up to the
maximum depth.
regards
Matthew J Fletcher
URL: <http://lists.rtems.org/pipermail/users/attachments/20130301/395fbee8/attachment.html>
