bfin simulator problems
Peng Fan van.freenix at gmail.com
Fri May 10 14:49:18 UTC 2013
Hi,
I have encounter a problem when using bfin simulator.
$bf537Stamp -i ticker.exe
bfin-rtems4.11-run is /opt/rtems-4.11/bin/bfin-rtems4.11-run
*** CLOCK TICK TEST ***
TA1  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA2  - rtems_clock_get_tod - 09:00:00   12/31/1988
TA3  - rtems_clock_get_tod - 09:00:00   12/31/1988
It stops at the 'TA3' and does not go on.
And when I use ezkit533 bsp with the command 'ezkit533 -i hello.exe', it
shows that:
"bfin-rtems4.11-run is /opt/rtems-4.11/bin/bfin-rtems4.11-run
_cec_raise: double fault at 0xffb00000 ! :("
I have tried skyeye 1.2.4 to run bfin, but some instructions can not be
decoded.
Thanks.
Regards,
Peng.
URL: <http://lists.rtems.org/pipermail/users/attachments/20130510/615d3b97/attachment.html>
