Source Builder failure on Ubuntu.
Karel Gardas karel.gardas at centrum.cz
Sun Sep 1 16:47:52 UTC 2013
Hello,
I'm trying to use source builder on ubuntu 12.04 AMD64, but the build
process fails with:
prep: arm-rtems4.11-kernel-4.11-1: %setup -q -c -n
arm-rtems4.11-kernel-4.11-1-4.11
making dir: /home/karel/development/rtems/rtems-source-builder/rtems/sources
download: http://ftp.rtems.org/ftp/pub/rtems/4.11/rtems-4.11.tar.bz2
git://git.rtems.org/rtems.git?reset=hard?pull ->
sources/rtems.git?reset=hard?pull
git://git.rtems.org/rtems.git?reset=hard?pull: error: <urlopen error no
host given>
Build Set: Time 0:24:09.458279
error: downloading
git://git.rtems.org/rtems.git?reset=hard?pull: all paths have failed,
giving up
this happen twice from two attempts so I guess this is not temporal ftp
server problem but probably more solid issue.
To invoke source-builder I've followed information given by Alan on his
blog here:
http://alanstechnotes.blogspot.cz/2013/03/setting-up-rtems-development.html
-- the step:
4. Build and install the toolchain
$ cd $HOME/development/rtems/rtems-source-builder/rtems
$ ../source-builder/sb-set-builder \
          --log=build-log.txt \
          --prefix=$HOME/development/rtems/compiler/4.11 \
           4.11/rtems-arm
is what fails here.
My question is: is there something I've done wrong or is it known issue
in source-builder or on ftp server?
Thanks!
Karel
