Bug in getcwd() also in 4.11 kernel
Hoefle Marco Marco.Hoefle at nanotronic.ch
Tue Oct 14 16:09:16 UTC 2014
Hello,
getcwd() seems also buggy on an external  FAT12 image. On 4.11 there is no crash but this behavior:
 RAM disks registered
disk addr 1: 0x400c6fa0, size: 1000000
disk addr 2: 0x40074060, size: 262144
format /dev/rda done.
mount return: 0
mount return: 0
               Starting 1 threads...
started thread 0: id: 0x0b010002, prio: 10
 starting shell
RTEMS SHELL (Ver.1.0-FRC):/dev/console. Oct 14 2014. 'help' to list commands.
[/] # pwd
[/] # ls
dev   mram  sdram
[/] # cdhello dude, this is tick nr: 0
[/] # cd mram
hello dude, this is tick nr: 1
[/mram] # cd template
[/mram/template] # pwd
/mram/template
[/mram/template] # ls
logs  param
[/mram/template] #
[/mram/template] # cd logs
mount return: 0
mount return: 0
 starting shell
[/] # pwd
[/] # ls
dev   mram  sdram
 [/] # cd mram
/mram/template
logs  param
[/mram/template] #
 [?] # pwd
I'll be happy to forward the test case to an rtems developer.
This behavior occurs only when mounting an external fat12 image generated this way:
NAME = libfatfsimg
BUILDDIR = build
all: $(NAME).a
.PHONY: $(NAME).a
$(NAME).o:
      @echo [GEN FATFS] $@
      @dd if=/dev/zero of=$(NAME) bs=256 count=1024 > /dev/null
      /sbin/mkfs.vfat -F 12 -S 512 -s 1 -r 512 -f 1 -v $(NAME)
      mcopy -b/ -i $(NAME) content/* ::/
      @xxd -i $(NAME) > $(NAME).c
      @echo [CC]  $@
      @$(CC) -c $(CFLAGS) -o $@ $(NAME).c
$(NAME).a: $(NAME).o
      @$(AR) rcs $@ $^
The object file is then linked against the rtems test application.
Marco
________________________________
From: users [mailto:users-bounces at rtems.org] On Behalf Of Rohner Thomas
Sent: Donnerstag, 2. Oktober 2014 12:11
To: Joel Sherrill; rtems-users at rtems.org
Subject: RE: Bug in getcwd()
Hello,
> We have a system with the following configuration.
> Platform:
> ·Chip GR712RC
> ·Board: GR712 Development Board
> ·Compiler RTEMS RCC (according to your websites version)
> ·RTOS: RTEMS
> ·Library: GR-RTEMS-DRIVER Version 1.2.1.0
I'm using FAT as filesystem. We have same phenomenon for FAT12 or FAT16!
Freundliche Grüsse / Kind regards,
Thomas Rohner
Entwicklungsingenieur Software
nanoTRONIC GmbH
Werkstrasse 27, CH - 3250 Lyss
T: +41 32 384 69 30, F: +41 32 384 69 31
www.nanotronic.ch <http://www.nanotronic.ch/>  | thomas.rohner at nanotronic.ch
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: Mittwoch, 1. Oktober 2014 20:11
To: Rohner Thomas; rtems-users at rtems.org
Subject: Re: Bug in getcwd()
On 10/1/2014 9:26 AM, Rohner Thomas wrote:
	Hello,
	maybe I found a bug in getcwd().
	We're using RTEMS 4.0 with Gaisler-Aeroflex....
	With our libraries I get an erroneous string when directory-depth is about 4 folders from root!
	When I use this string to read directory it crahes!
	Is there a limitation of string-length?
	I get the same results for
	               Char buffer[200];
	getcwd(buffer,sizeof(buffer));
	or
	               char* ret = getcwd(NULL,0);
Is this with the IMFS? What BSP?
Can you put together a full test example so we can
see what is really happening?
There is a POSIX constant for PATH_MAX as I recall but
it is quite large.
Thomas Rohner
nanoTRONIC GmbH
URL: <http://lists.rtems.org/pipermail/users/attachments/20141014/a9a4a8df/attachment-0002.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.rtems.org/pipermail/users/attachments/20141014/a9a4a8df/attachment-0002.jpg>
