Build with RSB - I got lost.
Stanisław Grzeszczak stgrzeszczak at gmail.com
Thu Mar 26 15:25:08 UTC 2015
Gedare,
I've followed Anand's PATH advice and got the bootstrap and make to work.
Time for the next steps.
2015-03-26 16:19 GMT+01:00 Gedare Bloom <gedare at rtems.org>:
> What about the OP, did this advice work for you Stanislaw?
> Gedare
> On Thu, Mar 26, 2015 at 11:11 AM, Joel Sherrill
> <joel.sherrill at oarcorp.com> wrote:
> > On 03/26/2015 10:07 AM, Anand Krishnan wrote:
> >> It did run for me!
> >> I just had to export the local bin path as it was on my machine.
> > Great.
> > Just so this thread ends with another piece of advice. I spent months
> > helping someone on and off and it turned out that they weren't setting
> > the PATH in each window. All sounded great on the phone. When we
> > set up a video conference, I saw the mistake in 30 seconds. :)
> >> On Thu, Mar 26, 2015 at 8:34 PM, Joel Sherrill <
> >> <mailto:joel.sherrill at oarcorp.com>> wrote:
> >>     On 03/26/2015 09:58 AM, Anand Krishnan wrote:
> >>         On Thu, Mar 26, 2015 at 8:18 PM, Joel Sherrill
> >>         <joel.sherrill at oarcorp.com <mailto:joel.sherrill at oarcorp.com>
> >>         <mailto:joel.sherrill at oarcorp.com>>> wrote:
> >>             On March 26, 2015 9:45:29 AM CDT, Anand Krishnan
> >>         <anandkp92 at gmail.com <mailto:anandkp92 at gmail.com>
> >>         <mailto:anandkp92 at gmail.com <mailto:anandkp92 at gmail.com>>>
> wrote:
> >>         >On Thu, Mar 26, 2015 at 8:07 PM, Joel Sherrill
> >>         >On 03/26/2015 09:29 AM, Stanisław Grzeszczak wrote:
> >>         >Q 1: Do the mismatched paths mean that the build went wrong?
> >>         Or should
> >>         >I just fix the paths by hand, or move the lib/include folders?
> >>         >(Q 2: Should the examples have already been built along with
> >>             everything
> >>         >else?)
> >>         >If you configured and built RTEMS using configure, make, etc
> and
> >>         >configured with
> >>         >--enable-tests=samples, the executable was there and has
> symbolic
> >>         >information in it.
> >>         >I have no idea what you did. If you used a native gcc or tried
> to
> >>         >compile it by hand,
> >>         >then it didn't work.
> >>         >When I had tried, I had to change the path variable to the
> >>         directory
> >>         >where RSB built the tool-set.
> >>         >This was the code for I had to use: export
> >>         >PATH=/home/development/rtems/4.11/bin:$PATH , before I ran
> >>         bootstrap.
> >>             What is the contents of that bin directory?
> >>             Do "type autoconf" and make sure you are getting the one
> >>         for RTEMS.
> >>         The bin directory had all the tools created for sparc:
> >>         sparc-rtems4.11-gcc, sparc-rtems4.11-gdb among others.
> >>         It was created after I build the sparc tool-set.
> >>     Then when you are at the top of the rtems source tree,
> >>     ./bootstrap should just run without trouble based on you putting
> >>     that directory at the head of your PATH.
> >>     Then.... something like this
> >>     $ cd ..
> >>     $ mkdir b-sis
> >>     $ cd b-sis
> >>     $ ../rtems/configure --target=sparc-rtems4.11
> >>     --enable-rtemsbsp=sis --enable-tests=samples
> >>     ... that should end with a message indicating sis is a BSP to be
> >>     built ...
> >>     $ make
> >>     $ find . -name "*.exe"
> >>     ... that should print a handful of executables..
> >>     $ sparc-rtems4.11-gdb `find . -name hello.exe`
> >>     .... gdb stuff ...
> >>     (gdb) tar sim
> >>     (gdb) load
> >>     (gdb) run
> >>     ... output...
> >>         >-- Joel Sherrill
> >>         >Ask me about RTEMS: a free RTOS
> >>         >Support and Training Available
> >>         >_______________________________________________
> >>         >users mailing list
> >>         >users at rtems.org <mailto:users at rtems.org>
> >>         <mailto:users at rtems.org <mailto:users at rtems.org>>
> >>         >http://lists.rtems.org/mailman/listinfo/users
> >>             --joel
> >>     --     -- Joel Sherrill
> > -- Joel Sherrill
> > users mailing list
> > users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20150326/6353e891/attachment-0002.html>
