error: no build set file found: arm/realview_pbx_a9_qemu.bset
Tue Feb 7 00:15:23 UTC 2017
On Mon, Feb 6, 2017 at 5:37 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Try
> ../source-builder/sb-set-builder --list-bsets
> to get a list of the valid bsets you may use.
The arm board is simulated as part of the qemu build
with qemu.bset Since that is not RTEMS specific it is
under the bare directory at the top if I recall correctly.
--joel
> On Sun, Feb 5, 2017 at 9:08 PM, Karim, Hassan
> <hassan.karim at bison.howard.edu> wrote:
> > I've been running in circles dor days trying to compile RTEMS for the
> > arm/realview_pbx_a9_qemu BSP.
> > what am I doing wrong?
> > When I run the setbuilder it says I don't have a bset for realview. I
> say to
> > myself, I know. I was this set builder would create it. But alas... it
> > doesn't. Am I missing a step?
> > I already built a qemu.bset and I've even gotten to the point where I
> built
> > the erc32 BSP and ran the ticker for sparc/erc32. So I thought I was
> ready
> > to compile.
> > ../source-builder/sb-set-builder --without-rtems
> --log=arm_realvoewbx.log
> > --prefix=$HOME/rtems/4.12 arm/realview_pbx_a9_qemu
> > RTEMS Source Builder - Set Builder, 4.12 (08f709966f97 modified)
> > Build Set: arm/realview_pbx_a9_qemu
> > Build Set: Time 0:00:00.002498
> > Build FAILED
> > Regards,
> > Hassan Karim, CISSP
> > https://www.linkedin.com/in/hassankarimcissp
> > Comp Sci Ph.D. Student
> > Howard University
> > (202) 569-1012
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20170206/358b2958/attachment-0002.html>
