zynq
D Peter Siddons siddons at bnl.gov
Wed Feb 22 17:43:17 UTC 2017
Hi Joel,
The one I'm using for rtems tests is this
(http://microzed.org/product/microzed). I have the 72020 version. We
also use the Picozed (http://picozed.org/product/picozed) which is a
similar product, but brings out more of the IO (including some
high-speed serial ports), while dropping the on-board peripheral
connectors (ethernet, USB, SD card). It can also host a bigger FPGA
(72030). We have built a couple of motherboards to host the picozed and
provide these interfaces. The CPU is the same on all of them, dual-core
Arm Cortex A9's, and they all have 1GB DDR4 memory and of course the
FPGA fabric. They all have a JTAG connector, but you can also program
the fabric through U-boot.
The microzed is really convenient, because all you need besides the
board is a micro-USB cable, which provides power and a serial console.
so your full development system easily fits in your briefcase :)
I think they are a control system designers dream :)
Pete.
On 02/22/2017 12:04 PM, Joel Sherrill wrote:
> On Wed, Feb 22, 2017 at 9:53 AM, D Peter Siddons <siddons at bnl.gov
> <mailto:siddons at bnl.gov>> wrote:
>     I have built the tools and RTEMS 4.12 using rsb, for arm, focusing
>     on the xilinx-zynq-zedboard bsp. It went very smoothly. I have
>     been able to run the samples (ticker, paranoia) on an Avnet
>     Microzed board, which is apparently close enough to the zedboard
>     to work.
> :) Is there a particular model? Did it come with a JTAG adapter?
>     Is anyone actively working on this platform? In particular, does
>     the multiprocessor support work? I didn't configure it into the
>     rtems build, in fact I'm not sure how to do so. I suppose I need
>     an "--enable-xxx" parameter to configure, but I couldn't easily
>     see what "xxx" should be.
> There are multiple projects using it so I am sure someone will speak up.
> You are looking for --enable-smp.
>     I'd also appreciate any pointers to setting up u-boot to
>     automatically boot the apps. So far I loaded and ran the binaries
>     by hand from the u-boot shell. soime
> This had best be answered by someone else.
>     THanks,
>     Pete.
>     D. Peter Siddons
>     Detector Development Group Leader
>     Photon Science Division, NSLS-II,
>     Bldg. 535B
>     Brookhaven National Laboratory
>     Upton, NY 11973
>     email:siddons at bnl.gov <mailto:siddons at bnl.gov>
>     Phone:(631) 344-2738 <tel:%28631%29%20344-2738>
>     _______________________________________________
>     users mailing list
>     users at rtems.org <mailto:users at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/users
>     <http://lists.rtems.org/mailman/listinfo/users>
D. Peter Siddons
Bldg. 535B
Upton, NY 11973
email: siddons at bnl.gov
Phone: (631) 344-2738
URL: <http://lists.rtems.org/pipermail/users/attachments/20170222/85cc66e5/attachment-0002.html>
