Installing cexp-2.2.3 for RTEMS 4.12
Alan Cudmore alan.cudmore at gmail.com
Fri Oct 6 14:48:02 UTC 2017
I have not used Cexp in a while. I am working on integrating support for
the RTEMS dynamic loader (RTL) in the OSAL and cFE, but it may take a while
for that to be integrated into the open source OSAL release.
For your immediate problem, would it be possible to try removing the #error
macro line?
 #error "This file is deprecated; remove this line if you absolutely have
to use it"
Alan
On Thu, Oct 5, 2017 at 5:06 PM, Akiv <akivjh at gmail.com> wrote:
> Hi All,
> I have built RTEMS 4.12 for the pc686 BSP. I am now trying to install cexp
> 2.2.3. My goal is to run pc-rtems according to this guide:
> https://github.com/nasa/cFE/tree/master/psp/fsw/pc-rtems.
> After configuring, when I run the make I get the following error.
> bash-4.1$ ../cexp-CEXP_Release_2_2_3/configure
> --with-rtems-top=/home/rtems/pc_rtems/development/rtems/4.12
> --host=i386-rtems4.12 --enable-std-rtems-installdirs
> bash-4.1$ make -j 8
> make  all-recursive
> make[1]: Entering directory `/home/rtems/pc_rtems/developm
> ent/rtems/kernel/b-cexp'
> Making all in pc686
> make[2]: Entering directory `/home/rtems/pc_rtems/developm
> ent/rtems/kernel/b-cexp/pc686'
> make  all-recursive
> make[3]: Entering directory `/home/rtems/pc_rtems/developm
> Making all in regexp
> make[4]: Entering directory `/home/rtems/pc_rtems/developm
> ent/rtems/kernel/b-cexp/pc686/regexp'
> make[4]: Nothing to be done for `all'.
> make[4]: Leaving directory `/home/rtems/pc_rtems/developm
> Making all in libtecla
> ent/rtems/kernel/b-cexp/pc686/libtecla'
> i386-rtems4.12-gcc -B/home/rtems/pc_rtems/develop
> ment/rtems/4.12/i386-rtems4.12/pc686/lib/ -specs bsp_specs -qrtems  -B
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/lib
> -mtune=pentiumpro -march=pentium  -I/home/rtems/pc_rtems/develo
> pment/rtems/4.12/i386-rtems4.12/pc686/lib/include
> -I/home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include
> -DPACKAGE_NAME=\"\" -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\"
> -DPACKAGE_STRING=\"\" -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\"
> -DPACKAGE=\"libtecla\" -DVERSION=\"1.0\" -DSTDC_HEADERS=1
> -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1 -DHAVE_STDLIB_H=1
> -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1 -DHAVE_INTTYPES_H=1
> -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1 -DHAVE_SYS_SELECT_H=1 -DHAVE_SELECT=1
> -I. -I../..//../cexp-CEXP_Release_2_2_3/libtecla
> -I../..//../cexp-CEXP_Release_2_2_3/libtecla/.. -DPACKAGE_NAME=\"\"
> -DPACKAGE_TARNAME=\"\" -DPACKAGE_VERSION=\"\" -DPACKAGE_STRING=\"\"
> -DPACKAGE_BUGREPORT=\"\" -DPACKAGE_URL=\"\" -DPACKAGE=\"libtecla\"
> -DVERSION=\"1.0\" -DSTDC_HEADERS=1 -DHAVE_SYS_TYPES_H=1 -DHAVE_SYS_STAT_H=1
> -DHAVE_STDLIB_H=1 -DHAVE_STRING_H=1 -DHAVE_MEMORY_H=1 -DHAVE_STRINGS_H=1
> -DHAVE_INTTYPES_H=1 -DHAVE_STDINT_H=1 -DHAVE_UNISTD_H=1
> -DHAVE_SYS_SELECT_H=1 -DHAVE_SELECT=1    -MT libtecla_a-getline.o -MD -MP
> -MF .deps/libtecla_a-getline.Tpo -c -o libtecla_a-getline.o `test -f
> 'getline.c' || echo '../..//../cexp-CEXP_Release_2
> _2_3/libtecla/'`getline.c
> -I../..//../cexp-CEXP_Release_2_2_3/libtecla/.. -D_POSIX_C_SOURCE=199506L
> -DPREFER_REENTRANT    -MT libtecla_r_a-getline.o -MD -MP -MF
> .deps/libtecla_r_a-getline.Tpo -c -o libtecla_r_a-getline.o `test -f
> In file included from ../..//../cexp-CEXP_Release_2_
> 2_3/libtecla/getline.c:154:0:
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:60:2:
> error: #error "This file is deprecated; remove this line if you absolutely
> have to use it"
> to use it"
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:62:8:
> error: redefinition of 'struct winsize'
>  struct winsize {
> In file included from /home/rtems/pc_rtems/developme
> nt/rtems/4.12/i386-rtems4.12/include/sys/ioctl.h:49:0,
> 2_3/libtecla/getline.c:59:
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ttycom.h:52:8:
> note: originally defined here
>  struct winsize {
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:74:0:
> warning: "IOCPARM_MASK" redefined
>  #define IOCPARM_MASK 0x1fff  /* parameter length, at most 13 bits */
> nt/rtems/4.12/i386-rtems4.12/include/sys/ioctl.h:45:0,
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioccom.h:47:0:
> note: this is the location of the previous definition
>  #define IOCPARM_MASK ((1 << IOCPARM_SHIFT) - 1) /* parameter length mask
> ../..//../cexp-CEXP_Release_2_2_3/libtecla/../rtems-hackdefs.h:76:0:
> warning: "_IOC" redefined
>  #define _IOC(inout,group,num,len) (inout | ((len & IOCPARM_MASK) << 16) |
> ((group) << 8) | (num))
> /home/rtems/pc_rtems/development/rtems/4.12/i386-rtems4.12/include/sys/ioccom.h:59:0:
>  #define _IOC(inout,group,num,len)     \
> have to use it"
> to use it"
>  struct winsize {
>  struct winsize {
> make[4]: *** [libtecla_r_a-getline.o] Error 1
> make[4]: *** Waiting for unfinished jobs....
> make[4]: *** [libtecla_a-getline.o] Error 1
> make[3]: *** [all-recursive] Error 1
> make[3]: Leaving directory `/home/rtems/pc_rtems/developm
> make[2]: *** [all] Error 2
> make[2]: Leaving directory `/home/rtems/pc_rtems/developm
> make[1]: *** [all-recursive] Error 1
> make[1]: Leaving directory `/home/rtems/pc_rtems/developm
> make: *** [all] Error 2
> Would someone be able to provide some insight?
> Best Regards,
> Akiv Jhirad
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20171006/ac4a10d9/attachment-0002.html>
