Error building libbsd
Nicolas Tsiogkas lou.nick at gmail.com
Thu Jun 21 14:26:13 UTC 2018
And apparently I forgot the host.
It is ubuntu 16.04:
Linux im-desktop-021 4.13.0-45-generic #50~16.04.1-Ubuntu SMP Wed May 30
11:18:27 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.9)
N.
On Thu, Jun 21, 2018 at 4:19 PM Nicolas Tsiogkas <lou.nick at gmail.com> wrote:
> Hi Joel,
>  waf-2.0.8 configure --prefix="$sandbox/5"
> --rtems-bsps=arm/xilinx_zynq_a9_qemu
> has the following output:
> Setting top to                           : /home/niko/sandbox/rtems-libbsd
> Setting out to                           :
> /home/niko/sandbox/rtems-libbsd/build
> RTEMS Version                            : 5
> Architectures                            : arm-rtems5
> Board Support Package                    : arm-rtems5-xilinx_zynq_a9_qemu
> Show commands                            : no
> Long commands                            : no
> Checking for program 'arm-rtems5-gcc'    :
> /home/niko/sandbox/5/bin/arm-rtems5-gcc
> Checking for program 'arm-rtems5-g++'    :
> /home/niko/sandbox/5/bin/arm-rtems5-g++
> Checking for program 'arm-rtems5-ld'     :
> /home/niko/sandbox/5/bin/arm-rtems5-ld
> Checking for program 'arm-rtems5-ar'     :
> /home/niko/sandbox/5/bin/arm-rtems5-ar
> Checking for program 'arm-rtems5-nm'     :
> /home/niko/sandbox/5/bin/arm-rtems5-nm
> Checking for program 'arm-rtems5-objdump' :
> /home/niko/sandbox/5/bin/arm-rtems5-objdump
> Checking for program 'arm-rtems5-objcopy' :
> /home/niko/sandbox/5/bin/arm-rtems5-objcopy
> Checking for program 'arm-rtems5-readelf' :
> /home/niko/sandbox/5/bin/arm-rtems5-readelf
> Checking for program 'arm-rtems5-strip'   :
> /home/niko/sandbox/5/bin/arm-rtems5-strip
> Checking for program 'rtems-ld'           :
> /home/niko/sandbox/5/bin/rtems-ld
> Checking for program 'rtems-tld'          :
> /home/niko/sandbox/5/bin/rtems-tld
> Checking for program 'rtems-bin2c'        :
> /home/niko/sandbox/5/bin/rtems-bin2c
> Checking for program 'tar'                : /bin/tar
> Checking for program 'gcc, cc'            :
> Checking for program 'ar'                 :
> Checking for program 'g++, c++'           :
> Checking for program 'gas, gcc'           :
> Compiler version (arm-rtems5-gcc)         : 7.3.0 20180125 (RTEMS 5, RSB
> 8ee4e8cd557c25fca59bb9751751ad4172530958, Newlib 3.0.0)
> Checking for RTEMS CPU options header     : started
> -> processing test results                : all ok
> Checking for RTEMS_DEBUG                  : no
> Checking for RTEMS_MULTIPROCESSING        : no
> Checking for RTEMS_NEWLIB                 : yes
> Checking for RTEMS_POSIX_API              : yes
> Checking for RTEMS_SMP                    : no
> Checking for RTEMS_NETWORKING             : no
> Checking for RTEMS header                 : started
> Checking for header dlfcn.h               : yes
> Checking for header rtems/pci.h           : yes
> Configure variant:                        :
> arm-rtems5-xilinx_zynq_a9_qemu-default
> Checking for header rtems/rtems-debugger.h : yes
> 'configure' finished successfully (0.744s)
> Cheers,
> Niko
> On Thu, Jun 21, 2018 at 4:09 PM Joel Sherrill <joel at rtems.org> wrote:
>> On Thu, Jun 21, 2018 at 8:52 AM, Nicolas Tsiogkas <lou.nick at gmail.com>
>> wrote:
>>> Hi,
>>> following the steps described in https://github.com/RTEMS/rtems-libbsd
>>> I get an error
>>> "Could not create the directory ///h" while trying to build with waf
>>> 2.0.8
>>> Is it a known problem?
>> Not to me.
>> What's your configure command and host?
>>> I have seen that the installation procedure has changed since 4.11 and
>>> now the tools and the bsps are installed in the same prefix, but that
>>> shouldn't matter I suppose.
>>> Thank you in advance.
>>> Regards,
>>> Niko
>>> users mailing list
>>> users at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20180621/a122e791/attachment-0002.html>
