Raspberry Pi Rtems-Graphical-Toolkit
Wed May 9 16:06:54 UTC 2018
Very nice blog Mikhail! And it looks to be great work!
Thank you for the complimentary things you said about RTEMS features.
I have a few questions.
+ Is this going to show up in the Qt free edition?
+ Any ideas on what RTEMS could do to improve our side of the
hosting Qt equation? Graphics has always been a challenge.
FWIW I took a stab at estimating porting Qt a few years ago. It is a large
body of software and a lot is just not appropriate for most embedded
devices.
I got a reasonable subset to build but never got funding to do the actual
work.
I am quite thrilled your effort was more successful.
Thanks.
--joel
On Fri, May 4, 2018 at 1:23 PM, Mikhail Svetkin <mikhail.svetkin at gmail.com>
wrote:
> Hi all,
> We started some researches (including Qt on RTEMS), take a look if you are
> interested.
> http://blog.qt.io/blog/2018/05/03/qt-microncontrollers-mcu/
> Mikhail Svetkin
> Software Engineer
> The Qt Company
> Sandakerveien 116
> 0484, Oslo, Norway
> mikhail.svetkin at qt.io
> +47 488 62 204
> http://qt.io
> <http://qt.io/>
> <http://www.facebook.com/Qt> <http://www.twitter.com/qtproject>
> <https://www.linkedin.com/company/the-qt-company/>
> <https://plus.google.com/104580575722059274792>
> <https://www.youtube.com/QtStudios>
> Best regards,
> Mikhail
> On 1 May 2018 at 19:01, Kirspel, Kevin <Kevin-Kirspel at idexx.com> wrote:
>> Another option is to not use X11 and draw directly to the frame buffer
>> device (i.e. /dev/fb0).  Qt supports this.
>> Kevin Kirspel
>> Electrical Engineer - Sr. Staff
>> Idexx Roswell
>> 235 Hembree Park Drive
>> Roswell GA 30076
>> Tel: (770)-510-4444 ext. 81642
>> Direct: (770)-688-1642
>> Fax: (770)-510-4445
>> *From:* users [mailto:users-bounces at rtems.org] *On Behalf Of *Emre Cetin
>> *Sent:* Tuesday, May 01, 2018 12:15 PM
>> *To:* users at rtems.org
>> *Subject:* Fwd: Raspberry Pi Rtems-Graphical-Toolkit
>> ---------- Forwarded message ----------
>> From: *Emre Cetin* <hsnemrecetin at gmail.com>
>> Date: 2018-05-01 19:13 GMT+03:00
>> Subject: Re: Raspberry Pi Rtems-Graphical-Toolkit
>> To: Chris Johns <chrisj at rtems.org>
>> Thank you for your help Chris, I did what you said and it worked.
>> However, I learned that Qt Applications works with X11 libraries in systems
>> like Rtems. And I have to compile the nxlib library for raspberrypi BSP in
>> the rtems-graphical-toolkit for X11. 'graphics\nxlib.bset' in rsb can not
>> be build as mentioned in "https://lists.rtems.org/piper
>> mail/devel/2015-August/012358.html
>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__lists.rtems.org_pipermail_devel_2015-2DAugust_012358.html&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=2qOzfS7qOLo1pWDBn2daTfb11BT4SII6DAGj7Nybgz0&s=FP3leA0B8WdfvIUwiGG0f2VRmehMyQCINAcYMEOWL8k&e=>".
>> I understand that the nxlib is included in microwindows library anymore,
>> but when I build 'graphics/microwindows.bset', will I also build nxlib?.
>> BSP 's X11 header files and so on. How do I add X11 header files to BSP and
>> other necessary files? What should I do at this point?
>> Best wishes,
>> Emre
>> 2018-05-01 3:22 GMT+03:00 Chris Johns <chrisj at rtems.org>:
>> On 01/05/2018 02:49, Emre Cetin wrote:
>> > Hello everyone,
>> Hi and welcome.
>> > I have a Rtems project with Raspberry pi, I need to compile a simple QT
>> program.
>> > I tried to run this project on Beaglebone Black, but it may not be as
>> fast as it
>> > should be, it seems easier on Rpi. And I work on the Rpi 1 model B. In
>> the last
>> > few days I am trying to establish the necessary libraries for QT, but I
>> have not
>> > been successful.
>> This sounds like an interesting project.
>> > I've been working on Rtems-Graphical-Toolbase, but I have not
>> > been successful in compilation. I tried a lot of ways but I do not know
>> how to
>> > load libraries manually yet, I am new to embedded systems.
>> Welcome to embedded and embedded real-time software.
>> > I finally used these instructions, it seemed the easiest way to me;
>> > (in right directory)
>> > ../source-builder/sb-set-builder \
>> >     --prefix=$HOME/development/rtems/compiler/5 \
>> >     --rtems-bsp=arm/raspberrypi \
>> >     --log=graphic-build-log.txt \
>> >     --with-rtems-bsp=raspberrypi \
>> >     --pkg-tar-files \
>> >     graphics/freetype2.bset \
>> >     graphics/libjpeg.bset \
>> >     graphics/libpng.bset \
>> >     graphics/libtiff.bset \
>> >     graphics/t1lib.bset \
>> > RTEMS Source Builder - Set Builder, 5 (f3b1700dfd4d)
>> > Build Set: graphics/microwindows.bset
>> > Build Set: graphics/freetype2.bset
>> > config: graphics/freetype-2.4.10-1.cfg
>> > package: freetype-v2.4.10-arm-rtems5-1
>> > error: hash: freetype-2.4.10.tar.gz: insecure: md5
>> > Build FAILED
>> > It seems that new packages are causing problems, and I do not know how
>> to update
>> > the codes. Can you give me some advice?
>> A change went into the RSB in October last year to stop using the MD5 and
>> SHA1
>> checksums as they are insecure. The ticket that covered this issue is:
>>  https://devel.rtems.org/ticket/2536
>> <https://urldefense.proofpoint.com/v2/url?u=https-3A__devel.rtems.org_ticket_2536&d=DwMFaQ&c=2do6VJGs3LvEOe4OFFM1bA&r=dbavT-WIJ4nBfQFKYnKdAD52Vyq3ZXSzrL9TAm21lZI&m=2qOzfS7qOLo1pWDBn2daTfb11BT4SII6DAGj7Nybgz0&s=W5nqzhQZQ8MD2Qny_KmidQ3uYRpLeCKJeVIEUl3iORE&e=>
>> It would seem some packages were missed and they need a better checksum.
>> Could
>> you please reopen the ticket and indicate the issue you have by pasting
>> in the
>> above output?
>> FYI the fix is easy, run a sha512 command on your host on the file or
>> patch
>> which should be in the `sources` or `patches` directory and then update
>> the line
>> in the related file. The freetype config file is:
>>  rtems/config/graphics/freetype-2.4.10-1.cfg
>> On the line starting with `%hash` change `md5` to `sha512` and paste in
>> the
>> SHA512 checksum.
>> I see ...
>>  libjpeg-9a-1.cfg
>>  libpng-1.5.24-1.cfg
>>  libpng-1.6.21-1.cfg
>>  libtiff-4.0.2-1.cfg
>>  libtiff-4.0.6-1.cfg
>>  microwindows-0.93-dev-1.cfg
>>  t1lib-5.1.2-1.cfg
>> ... are still using MD5 and will need updating.
>> We welcome patches, it is often the fastest way to get something like
>> this fixed. :)
>> Thanks
>> Chris
>> users mailing list
>> users at rtems.org
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20180509/b78d651a/attachment-0002.html>
