rsb problem with python
Siddons, David siddons at bnl.gov
Mon May 28 22:23:19 UTC 2018
Hi Amaan,
   Actually,  /home/peter/miniconda3/bin/python is a soft link to /home/peter/miniconda3/bin/python3.6 already! Does rsb not follow links?
Pete.
________________________________
Sent: Monday, May 28, 2018 6:05 PM
To: Siddons, David
Cc: users at rtems.org
Subject: Re: rsb problem with python
Hey David!
It looks to me like Anaconda doesn't install the "alias" binaries specifying the version (for eg. both "python" and "python3.6"). I believe the fix in your case should be as simple as copying your existing binary with the following command:
cp /home/peter/miniconda3/bin/python /home/peter/miniconda3/bin/python3.6
On Tue, May 29, 2018, 3:28 AM Siddons, David <siddons at bnl.gov<mailto:siddons at bnl.gov>> wrote:
While building rsb for arm-rtems I got this problem:
checking for python... /home/peter/miniconda3/bin/python
checking for python3.6... no
configure: error: python is missing or unusable
Makefile:9095: recipe for target 'configure-gdb' failed
make[1]: *** [configure-gdb] Error 1
make[1]: Leaving directory '/home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/build'
Makefile:848: recipe for target 'all' failed
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex  /home/peter/development/rtems/src/rtems-source-builder/rtems/build/arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1/doit
error: building arm-rtems5-gdb-8.0.1-x86_64-linux-gnu-1peter at peter-Latitude-E7240:~/development/rtems/src/rtems-source-builder/rtems$
I am running Ubuntu:
peter at peter-Latitude-E7240:/etc$ lsb_release -a
LSB Version:    core-9.20160110ubuntu0.2-amd64:core-9.20160110ubuntu0.2-noarch:printing-9.20160110ubuntu0.2-amd64:printing-9.20160110ubuntu0.2-noarch:security-9.20160110ubuntu0.2-amd64:security-9.20160110ubuntu0.2-noarch
Distributor ID: Ubuntu
Description:    Ubuntu 16.04.4 LTS
Release:        16.04
Codename:       xenial
then:
python -V
Python 3.6.1 :: Continuum Analytics, Inc.
This comes from an Anaconda installation. If I remove the path entry which causes that I get python 2.7, which is the default Ubuntu 16.04 version. Do I need to install Python 3.6?
Pete.
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20180528/b3b99195/attachment-0002.html>
