stm32f4 __wfi
Jython googcheng at gmail.com
Wed Apr 24 00:35:14 UTC 2019
yes, I need to do low power for stm32f4
will this line work __asm__ volatile ("wfi");?
On Tue, Apr 23, 2019 at 10:28 PM Christian Mauderer <
christian.mauderer at embedded-brains.de> wrote:
> Am 22.04.19 um 09:47 schrieb Jython:
> > HI, ALL!
> > wfi
> http://www.keil.com/support/man/docs/armcc/armcc_chr1359125004400.htm
> > how can i call the arm __wfi?
> > users mailing list
> > users at rtems.org
> > http://lists.rtems.org/mailman/listinfo/users
> Hello Jython,
> WFI is an assembler instruction. The Keil wrapper isn't available in
> gcc. I know of no direct replacement. Most likely you need a gcc inline
> assembly for that.
> May I ask why you would need "wfi"? If you use a operating system, the
> system typically handles such low level stuff for you. The only
> application that springs to mind for that instruction is overwriting the
> idle loop to save energy.
> Best regards
> Christian
> embedded brains GmbH
> Herr Christian Mauderer
> Dornierstr. 4
> D-82178 Puchheim
> Germany
> email: christian.mauderer at embedded-brains.de
> Phone: +49-89-18 94 741 - 18
> Fax:   +49-89-18 94 741 - 08
> PGP: Public key available on request.
URL: <http://lists.rtems.org/pipermail/users/attachments/20190424/39b9ff9b/attachment-0002.html>
