compile error in rtems/confdefs header
Wed Nov 27 10:07:22 UTC 2019
On 27/11/2019 10:09, Vishav.Vishav at dlr.de wrote:
> Thanks for the reply. These are the compiler options that I use:
> -std=c99
This is likely the problem. Using -std=gnu99 should work.
Independent of this, why do you want to use an obsolete 20 year old
standard which knows nothing about threads?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
