installing Doorstop on macOS (for RTEMS use)
Thu Oct 31 06:33:23 UTC 2019
On 31/10/19 5:21 pm, Sebastian Huber wrote:
> On 30/10/2019 21:39, Chris Johns wrote:
>> On 31/10/19 12:24 am, Sebastian Huber wrote:
>>> On 25/10/2019 01:18, Chris Johns wrote:
>>>> On 24/10/19 9:52 pm, Andrew Butterfield wrote:
>>>>>     I got around to doing a doorstop install that does not rely on homebrew,
>>>>> using the python.org <http://python.org> distribution for 3.8
>>>>> Everything worked fine - python3 is installed in /Library just like the OS X
>>>>> native python 2.7
>>>>> Doorstop runs just fine too.
>>>> Excellent and thanks for this. I think this or the other solution that was
>>>> posted should work. This means I cannot see any blockers for Doorstop on our
>>>> supported hosts.
>>> Ok, great. Thanks for all the testing and other valuable input.
>>> I think on macOS we have now five options:
>>> 1. homebrew
>>> 2. MacPorts
>>> 3. python.org installer
>>> 4. pyenv
>>> 5. wait for Apple to ship a Python 3
>>> We need a recommendation for the user manual.
>> I suggest 3. because it is the simplest to do and it does not step on global
>> paths.
> Ok.
>> Can we assume Doorstop is only needed if developing or maintaining RTEMS?
> Yes, definitely.
> You mean the user manual is not the right place to add Python 3.6+ to the host
> computer requirements? We could add this to the RTEMS Software Engineering manual.
Good question. If there is nothing in the User Manual related to developing or
maintaining RTEMS then yes the eng manual would be the correct place. I am sure
we will find other things that are specific to each host. For example I will
need to add a section to the eng manual on the release procedure and this has a
range of specific packages that are needed.
