BSP testing and building applications
Richi Dubey richidubey at gmail.com
Mon Aug 10 04:05:49 UTC 2020
Hi,
Until someone helps you with your exact question, follow this guide:
https://docs.rtems.org/branches/master/user/start/gsoc.html
It would have answers to almost all your questions.
Good Luck!
On Mon, Aug 10, 2020 at 2:01 AM Zacchaeus Liang <zliang111 at gmail.com> wrote:
> Hello,
> I'm Zack and I'm currently finishing up my university degree in comp sci.
> I'm really interested in aviation and aerospace systems. I want to get into
> rtems to learn more about rtos and contribute to rtems !
> Currently I'm trying to build rtems and test and bsp. Hoping to then
> contribute. I followed one of you GSOC student's tutorials and tried to go
> ahead. I'm trying to build the test the bsp right now.
> here is his blog post
> https://medium.com/@mritunjaysharma394/installing-rtems-ecosystem-and-building-your-first-bsp-993d1cf38902
> I tried to run the bsp testing like this and it says the ini file is not
> found.  Is this the right bsp argument?  After this i'm going to try to
> build an application and would like to know the right path to install it.
> Any tips on looking for easy things to learn to patch? Thanks in advance i
> know it's a handful for questions!
> zakonrockets at zakonrockets-Inspiron-15-7000-Gaming:~/development/rtems/kernels-5/pcp-386$ rtems-test --rtems-bsp=i386-rtems5 --rtems-tools=$HOME/development/rtems/5
> RTEMS Testing - Tester, 5.0.not_released
>  Command Line: /home/zakonrockets/development/rtems/5/bin/rtems-test --rtems-bsp=i386-rtems5 --rtems-tools=/home/zakonrockets/development/rtems/5 Host: Linux zakonrockets-Inspiron-15-7000-Gaming 5.3.0-62-generic #56-Ubuntu SMP Tue Jun 23 11:20:52 UTC 2020 x86_64 Python: 3.7.5 (default, Apr 19 2020, 20:18:17) [GCC 9.2.1 20191008]Host: Linux-5.3.0-62-generic-x86_64-with-Ubuntu-19.10-eoan (Linux zakonrockets-Inspiron-15-7000-Gaming 5.3.0-62-generic #56-Ubuntu SMP Tue Jun 23 11:20:52 UTC 2020 x86_64 x86_64)error: cannot find bsp configuration file: i386-rtems5.ini
> this is the output of my testing. Thanks for all the help!!
> Zack
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20200810/1c44db60/attachment-0001.html>
