Overcoming a 256 bytes console/uart limit
Ian Caddy ianc at goanna.iinet.net.au
Thu Aug 27 00:40:36 UTC 2020
Hi,
On 26/08/2020 5:36 pm, Schweikhardt, Jens (TSPCE3-TL4) wrote:
> Hello world\n
> I’m observing a 256 byte input limit with RTEMS 5 on riscv that I
> don’t know how to overcome.
> We are using the RTEMS console driver and newlib stdio.
> The effect is that an fgets() appears to only accept 256 characters,
> specifically if we connect via
> picocom on a Linux box, we can type exactly 256 chars and then no more
> characters are accepted.
> My first guess was that stdio buffers are 256 byte by default, which
> they seem to be judging from
> grepping for BUFSIZ. Then using setvbuf should be the way to increase
> their size. But setvbuf had no effect.
> Next guess was that it is a limit of picocom. So we tried using Python
> with pyserial to send data.
> Same problem.
Not sure if is the best practice, but we override the size of the
buffers in:
rtems-5/cpukit/libcsupport/src/termios.c:87
|static size_t rtems_termios_cbufsize = 1024; static size_t
rtems_termios_raw_input_size = 1024; static size_t
rtems_termios_raw_output_size = 1024; This overrides the raw input and
output and the cooked buffer. Hope this helps. regards, Ian Caddy Goanna
Technologies Pty Ltd |
URL: <http://lists.rtems.org/pipermail/users/attachments/20200827/5c10846f/attachment.html>
