Problem in Building BSP
Prithvi Chakravarthy prithvichakravarthy at gmail.com
Sun Jan 12 16:01:20 UTC 2020
Hi,
I've been trying to set up RTEMS. So far I have been following the
documentation and i when i building BSP.
When I entered the following command:
HOME/quick-start/src/rtems/configure \
> --prefix=$HOME/quick-start/rtems/5 \
> --enable-maintainer-mode \
> --target=sparc-rtems5 \
> --enable-rtemsbsp=erc32 \
> --enable-tests
I had the following code as output:
/home/prithvi/quick-start/src/rtems/configure: line 472: sed: command not
found
/home/prithvi/quick-start/src/rtems/configure: line 471: expr: command not
found
found
/home/prithvi/quick-start/src/rtems/configure: line 486: sed: command not
found
: error: cannot create .lineno; rerun with a POSIX shell
Any help would be highly appreciated.
Regards,
URL: <http://lists.rtems.org/pipermail/users/attachments/20200112/45a4e189/attachment.html>
