Python problems on OS X
Tue Nov 17 20:00:55 UTC 2020
On Tue, Nov 17, 2020 at 3:19 AM Andrew Butterfield
<Andrew.Butterfield at scss.tcd.ie> wrote:
> I keep getting a python error when trying to build the tool suite on
> OS X. The end of the error log is:
> checking whether to use python... /Library/Frameworks/Python.framework/Versions/2.7/bin/python2
> checking for python... no
> configure: error: no usable python found at /Library/Frameworks/Python.framework/Versions/2.7/bin/python2
> make[1]: *** [configure-gdb] Error 1
> make: *** [all] Error 2
> shell cmd failed: /bin/sh -ex  /Users/butrfeld/REPOS/esa-qual/modules/rsb/rtems/build/sparc-rtems6-gdb-0295dde-x86_64-apple-darwin19.6.0-1/do-build
> error: building sparc-rtems6-gdb-0295dde-x86_64-apple-darwin19.6.0-1
> What are the criteria for python to be "useable"?
> I have removed all traces of non-native (brew) pythons that I can find.
Just a guess, sometimes there are separate user-facing python
environments vs system-level python that can be interfaced from
programs to call-out to python. I've seen that error raised more often
as "Unable to find Python.h" but I'm thinking maybe it is a similar
issue here. The linux distros package separately python and python-dev
(or similar) to allow linking to Python from other languages. You
might need to look for something similar for Mac maybe?
> I followed the virtual environment instructions in the rtems-central README.md
> :- which python
> :- which python3
> /Library/Frameworks/Python.framework/Versions/3.8/bin/python3
> My machine is running macOS Catalina 10.15.7
> Any ideas?
> Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
> Lero at TCD, Head of Software Foundations & Verification Research Group
> School of Computer Science and Statistics,
> Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>                          http://www.scss.tcd.ie/Andrew.Butterfield/
> users mailing list
> users at rtems.org
