RTEMS5 checksum failure file: sources/jpegsrc.v9a
Matt Rippa mrippa at gemini.edu
Mon Feb 1 08:03:22 UTC 2021
Hi all,
I have a quick test here that fails. This worked a few weeks ago.
Thanks,
-Matt
mkdir quick-test
cd quick-test/
git clone https://github.com/RTEMS/rtems-source-builder.git rsb
cd rsb/
git checkout 5
cd rtems
../source-builder/sb-set-builder --source-only-download 5/bsps/pc
RTEMS Source Builder - Set Builder, 5 (803d42cda7b3)
Build Set: 5/bsps/pc
Build Set: 5/rtems-i386.bset
Build Set: 5/rtems-autotools.bset
Build Set: 5/rtems-autotools-internal.bset
config: tools/rtems-autoconf-2.69-1.cfg
package: autoconf-2.69-x86_64-linux-gnu-1
Creating source directory: sources
download: https://ftp.gnu.org/gnu/autoconf/autoconf-2.69.tar.gz ->
sources/autoconf-2.69.tar.gz
downloading: sources/autoconf-2.69.tar.gz - 1.8MB of 1.8MB (100%)
config: tools/rtems-automake-1.12.6-1.cfg
...SNIP...
Build Set: graphics/libjpeg.bset
config: graphics/libjpeg-9a-1.cfg
package: libjpeg-v9a-i386-rtems5-1
download: http://www.ijg.org/files/jpegsrc.v9a.tar.gz ->
sources/jpegsrc.v9a.tar.gz
downloading: sources/jpegsrc.v9a.tar.gz - 976.5kB of 976.5kB (100%)
warning: checksum error: jpegsrc.v9a.tar.gz
error: checksum failure file: sources/jpegsrc.v9a.tar.gz
Build FAILED
Build Set: Time 0:00:01.201104
Build Set: Time 0:00:05.636248
Build Set: Time 0:01:05.610093
Build FAILED
URL: <http://lists.rtems.org/pipermail/users/attachments/20210131/d75ffba4/attachment.html>
