Testing SMP Configuration with rtems-test
Jiri Gaisler jiri at gaisler.se
Sat Feb 19 13:48:36 UTC 2022
You should add -m 4 to the bsp_run_opts in the leon3-sis-cov.ini file,
which is in
/opt/rtems/6/share/rtems/tester/rtems/testing/bsps/leon3-sis-cov.ini
(or similar depending on where you installed RBS).
Jiri.
On 2022-02-19 09:26, Jerzy J wrote:
> Hi,
> I've been trying to get some coverage reports on my tests. I'm using RTEMS
> 6 and gr712rc/leon3 bsps.
> Normally I run my tests using:
> `./sparc-rtems6-sis -leon3 -r s -m 4
> $HOME/RTEMS/src/rtems/build/sparc/gr712rc/testsuites/validation/ts-model-barrier-mgr-0.exe`
> , where I can specify `-m 4`.
> However when using rtems-test:
> `./rtems-test --rtems-tools=$HOME/RTEMS/rtems/6 --log=log_leon3_sis
> --rtems-bsp=leon3-sis-cov --coverage
> ~/RTEMS/src/rtems/build/sparc/gr712rc/testsuites/validation/ts-model-barrier-mgr-0.exe
> My tests fail, since as I can see in the log it runs:
> `=>  exe: /home/yoman/RTEMS/rtems/6/bin/sparc-rtems6-sis -leon3 -nouartrx
> -r -tlim 200 s -cov
> /home/yoman/RTEMS/src/rtems/build/sparc/gr712rc/testsuites/validation/ts-model-barrier-mgr-0.exe`
> resulting in only 1 cpu online.
> Is there a way I can pass `-m 4` into rtems-test or is there some extra
> configuration step I'm probably not aware of that handles this?
> My 'config.ini' file:
> `[sparc/gr712rc]
> RTEMS_SMP = True
> BUILD_TESTS = True`
> Thank you in advance and all the best!
> Jerzy
> users mailing list
> users at rtems.org
