RTEMS 5 on mcp750 fails
Miroslaw Dach miroslaw.dach at gmail.com
Sat May 21 19:42:48 UTC 2022
Hi Joel,
>If it is configured for unified workspace, you wouldn't specify extra
stacks and this wouldn't have been tripped.
Do you mean that CONFIGURE_EXTRA_TASK_STACKS is not taken into account
when CONFIGURE_UNIFIED_WORK_AREAS is defined?
I have checked
the powerpc-rtems5/mcp750/lib/include/rtems/confdefs/wkspace.h and it seems
the CONFIGURE_EXTRA_TASK_STACKS is used to calculate the stack size?
#define _CONFIGURE_STACK_SPACE_SIZE \
  ( _CONFIGURE_INIT_TASK_STACK_EXTRA \
    + _CONFIGURE_POSIX_INIT_THREAD_STACK_EXTRA \
    + _CONFIGURE_LIBBLOCK_TASKS_STACK_EXTRA \
    + CONFIGURE_EXTRA_TASK_STACKS \
    + rtems_resource_maximum_per_allocation( _CONFIGURE_TASKS ) \
      * _Configure_From_stackspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) \
CONFIGURE_MAXIMUM_POSIX_THREADS ) \
CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) \
    + _CONFIGURE_HEAP_HANDLER_OVERHEAD )
#else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
What is the meaning of CONFIGURE_UNLIMITED_ALLOCATION_SIZE . Does it
express the size in KB?
Currently epics defines:
#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE 32
#define CONFIGURE_UNLIMITED_OBJECTS
Best Regards
Mirek
sob., 21 maj 2022 o 10:06 Joel Sherrill <joel at rtems.org> napisał(a):
> On Sat, May 21, 2022, 11:02 AM Miroslaw Dach <miroslaw.dach at gmail.com>
> wrote:
>> Hi Hainz,
>> Thanks for the indication. I have exactly found this setting and am going
>> to reduce
>> CONFIGURE_EXTRA_TASK_STACKS which is currently setup by default in EPICS
>> to 32MB.
>> The mcp750 has just 32MB so it is no wonder that it does not work.
> Unified and unlimited can avoid some issues.
> --joel
>> I will test the new configuration next week.
>> Have a nice weekend
>> Best Regards
>> Mirek
>> sob., 21 maj 2022 o 05:39 Heinz Junkes <junkes at fhi-berlin.mpg.de>
>> napisał(a):
>>> Hi Mirek,
>>> You can find the configuration of the RTEMS at EPICS here:
>>> epics-base/modules/libcom/RTEMS/posix/rtems_config.c
>>> There for example
>>> #define CONFIGURE_EXTRA_TASK_STACKS         (4000 *
>>> RTEMS_MINIMUM_STACK_SIZE)
>>> #define CONFIGURE_UNIFIED_WORK_AREAS
>>> best regards,
>>> Heinz
>>> > On 21. May 2022, at 00:21, Joel Sherrill <joel at rtems.org> wrote:
>>> > On Fri, May 20, 2022 at 3:55 PM Miroslaw Dach <miroslaw.dach at gmail.com
>>> > wrote:
>>> >> Hi Chris,
>>> >> Thank you very much for your expertise and attached links which are
>>> very
>>> >> helpful.
>>> >> As regards the INTERNAL_ERROR_TOO_LITTLE_WORKSPACE error message:
>>> >> Is it possible to determine with some debug information what is the
>>> >> foreseen by RTEMS WORKSPACE size?
>>> > This CONFIGURE_MEMORY_OVERHEAD is there as a mechanism to toss
>>> > extra memory at the workspace in case confdefs.h makes a mistake. I
>>> think
>>> > this
>>> > is more likely to be something else like a misconfigured system. But
>>> adding
>>> > this
>>> > to your RTEMS configuration with some chunk of memory like 128K might
>>> > allow this to proceed. But if it is a memory allocation error in the
>>> BSP
>>> > like
>>> > not assigning memory right to RTEMS, this won't fix it. See:
>>> https://docs.rtems.org/branches/master/c-user/config/general.html#configure-memory-overhead
>>> > Chris has touched one of the boards in the motorola_powerpc family
>>> > more recently than I have. I would think this would work unless
>>> something
>>> > is off in the EPICS configuration of RTEMS. There was a discussion of
>>> the
>>> > EPICS RTEMS configuration with Till recently on tech-talk and I thought
>>> > it looked ok.
>>> > --joel
>>> >> Best Regards
>>> >> Mirek
>>> >> śr., 18 maj 2022 o 00:53 Chris Johns <chrisj at rtems.org> napisał(a):
>>> >>> On 18/5/2022 9:36 am, Miroslaw Dach wrote:
>>> >>>> Dear RTEMS Users and Developers,
>>> >>>> I have built RTEMS 5 with EPICS 7 and tried to boot my application
>>> on
>>> >>>> mcp750 cPCI board.
>>> >>>> The first thing that I have encountered is that the boot file is in
>>> the
>>> >>> elf
>>> >>>> format so I have
>>> >>>> converted it to the binary one.:
>>> >>>> powerpc-rtems5-objcopy -I elf32-powerpc -O binary myApp.boot
>>> >>> myApp.boot.bin
>>> >>> We removed the various post-link hooks.
>>> >>>> So far so good
>>> >>>> Next, I booted the system with my app and it fails in the
>>> *bsp_early*
>>> >>>> function in
>>> >>>> bsps/powerpc/motorola_powerpc/start/bspstart.c
>>> >>>> The boot sequence:
>>> >>>> Network Boot File load in progress... To abort hit <BREAK>
>>> >>>> Bytes Received =&1270208, Bytes Loaded =&1270208
>>> >>>> Bytes/Second =&635104, Elapsed Time =2 Second(s)
>>> >>>> Residual-Data Located at: $01F88000
>>> >>>> Model: (e2)
>>> >>>> Serial: MOT0000000
>>> >>>> Processor/Bus frequencies (Hz): 366680480/66671508
>>> >>>> Time Base Divisor: 4000
>>> >>>> Memory Size: 2000000
>>> >>>> Residual: 1f88000 (length 27148)
>>> >>>> PCI: Probing PCI hardware
>>> >>>> RTEMS 5.0.0/PPC load:
>>> >>>> Uncompressing the kernel...
>>> >>>> done
>>> >>>> Now booting...
>>> >>>> Welcome to rtems-5.0.0 (PowerPC/Generic (classic FPU)/mcp750) on
>>> >> Mesquite
>>> >>>> cPCI (MCP750)
>>> >>>> idreg 0 = 0x1208029271
>>> >>>> OpenPIC found at 0xc1000000.
>>> >>>> pci : Configuring interrupt routing for 'Mesquite cPCI (MCP750)'
>>> >>>> pci : No bridge from bus 0 towards root found
>>> >>>> pci : Device 1:0x0b:0 routed to interrupt_line 27
>>> >>>> pci : Device 1:0x0d:0 routed to interrupt_line 25
>>> >>>> Cleared PCI errors: pci_stat was 0x2280
>>> >>>> OpenPIC Version ? (2 CPUs and 16 IRQ sources) at 0x3238002688
>>> >>>> OpenPIC Vendor 0 (Unknown), Device 0 (Unknown), Stepping 2
>>> >>>> OpenPIC timer frequency is 8333848 Hz
>>> >>> This all looks OK.
>>> >>>> *** FATAL ***
>>> >>>> fatal source: 0 (INTERNAL_ERROR_CORE)
>>> >>>> fatal code: 2 (INTERNAL_ERROR_TOO_LITTLE_WORKSPACE)
>>> >>>> RTEMS version:
>>> 5.0.0.fc89cc76804499eba3f3bc4097b795a84f07571a-modified
>>> >>>> RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (6225eadda1de), Newlib
>>> >>> 7947581)
>>> >>>> executing thread is NULL
>>> >>>> My application in the binary format uncompressed with stripped
>>> symbols
>>> >>> is a
>>> >>>> 2.3M + 501K bootloader so I do not think that it
>>> >>>> is an issue with the WORKSPACE? The mcp750 has 32MB of RAM.
>>> >>>> How to detect what is the real cause of
>>> >>>> Would it be the problem with the linker script ppcboot.lds?
>>> >>> I do not think so. I suggest you check the Classic API Guide here:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/intro.html#sizing-the-rtems-workspace
>>> >>> The accounting of memory is better and this means the extra space
>>> needed
>>> >>> may
>>> >>> need to be adjusted. I am not sure where in EPCIS this is controlled
>>> and
>>> >>> if it
>>> >>> can be overridden in your local configuration.
>>> >>> RTEMS 5 has a unified workspace and heap. This means the heap and
>>> >>> workspace can
>>> >>> use memory until it is all used. The benefit is not need to manage
>>> the
>>> >>> workspace
>>> >>> size statically:
>>> https://ftp.rtems.org/pub/rtems/releases/5/5.1/docs/html/c-user/config/general.html#configure-unified-work-areas
>>> >>> Chris
>>> >> _______________________________________________
>>> >> users mailing list
>>> >> users at rtems.org
>>> >> http://lists.rtems.org/mailman/listinfo/users
>>> > users mailing list
>>> > users at rtems.org
