How can I use --with-rtems-bspopts properly?
Y. HB sprhawk at gmail.com
Fri Sep 16 10:16:16 UTC 2022
Well
Just only use `TMS570_USE_HWINIT_STARTUP=1 ARM_TMS570LC4357=1
BSP_MINIMUM_TASK_STACK_SIZE=2048` after configure will make the
configuration. I thought --with-rtems-bspopts should do it.
On Fri, Sep 16, 2022 at 5:45 PM Y. HB <sprhawk at gmail.com> wrote:
> Hello,
> I am working on tms570 bsp
> I want to change some bspopts , but I cannot get the default value
> overridden via --with-rtems-bspopts, what correct way should I do?
> I used following command to configure RTEMS bsp
> ../../rtems-master/configure  OTHER-OPTIONS
> --with-rtems-bspopts="TMS570_USE_HWINIT_STARTUP=1 ARM_TMS570LC4357=1
> BSP_MINIMUM_TASK_STACK_SIZE=2048"
> But the generated bspopts.h is not changed with above values.
URL: <http://lists.rtems.org/pipermail/users/attachments/20220916/c5524f09/attachment.htm>
