RSB build fails on M1 Macbook Pro
Karel Gardas karel.gardas at centrum.cz
Tue Sep 20 13:41:24 UTC 2022
You are missing isl library header file:
configure:6284: /usr/bin/cc -O2 -pipe -fbracket-depth=1024
-I/Users/butrfeld/REPOS/RTEMS/src/rsb/rtems/build/tmp/sb-501/tools/rtems-default-tools/Users/butrfeld/RTEMS/rtems/6/include
-o conftest -g -O2
-L/Users/butrfeld/REPOS/RTEMS/src/rsb/rtems/build/tmp/sb-501/tools/rtems-default-tools/Users/butrfeld/RTEMS/rtems/6/lib
  -lisl -lmpc -lmpfr -lgmp conftest.c  -lisl -lgmp >&5
conftest.c:10:10: fatal error: 'isl/schedule.h' file not found
#include <isl/schedule.h>
1 error generated.
Karel
On 9/20/22 15:35, Andrew.Butterfield at scss.tcd.ie wrote:
> Hi Karel,
> Gdb config.log now attached
> Andrew
> On 20/09/2022, 14:17, "Karel Gardas" <karel.gardas at centrum.cz> wrote:
>      Usually just last page is enough. Anyway, your report reports that the
>      compilation fails on gdb configure with:
>      configure: WARNING: MPFR is missing or unusable; some features may be
>      unavailable.
>      checking whether to use python... /opt/homebrew/bin/python3
>      checking for python... no
>      configure: error: no usable python found at /opt/homebrew/bin/python3
>      make[1]: *** [configure-gdb] Error 1
>      if you look into gdb build directory you will see config.log there which
>      may tell you more about why your homebrew python3 fails.
>      Karel
>      On 9/20/22 15:02, Andrew Butterfield wrote:
>      > Hi Karel,
>      > here it is - I didn't want to attach this unless necessary!
>      > Regards,
>      >    Andrew
>      > Andrew Butterfield     Tel: +353-1-896-2517     Fax: +353-1-677-2204
>      > Lero at TCD, Head of Software Foundations & Verification Research Group
>      > School of Computer Science and Statistics,
>      > Room G.39, O'Reilly Institute, Trinity College, University of Dublin
>      >                           http://www.scss.tcd.ie/Andrew.Butterfield/
>      > -----Original Message-----
>      > From: Karel Gardas <karel.gardas at centrum.cz>
>      > Date: Tuesday 20 September 2022 at 14:00
>      > To: "Andrew.Butterfield at scss.tcd.ie" <Andrew.Butterfield at scss.tcd.ie>, "users at rtems.org" <users at rtems.org>
>      > Subject: Re: RSB build fails on M1 Macbook Pro
>      >      JFYI: 2 months ago I pushed patches in order to make M1 working at least
>      >      for arm target. As devil is in the detail you will also need to provide
>      >      rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt for
>      >      investigation.
>      >      Karel
>      >      On 9/20/22 14:55, Andrew.Butterfield at scss.tcd.ie wrote:
>      >      > Dear all,
>      >      > I tried to follow the Quickstart on my new M1 Macbook Pro (Apple Silicon),
>      >      > which one of my students is also trying to do.
>      >      > It fails with the following error
>      >      > downloading: sources/gdb-11.2.tar.xz - 21.0MB of 21.0MB (100%)
>      >      > building: sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
>      >      > error: building sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1
>      >      > Build FAILED
>      >      >    See error report: rsb-report-sparc-rtems6-gdb-11.2-x86_64-apple-darwin21.6.0-1.txt
>      >      > Build Set: Time 0:06:26.055237
>      >      > Build Set: Time 0:06:26.058387
>      >      > Build FAILED
>      >      > python maps to /usr/local/bin/python - it's a Mach-O 64-bit executable x86_64
>      >      > python --version is 3.6.8
>      >      > There is a  homebrew python3 but it's an arm64 executable, so seems not to be implicated.
>      >      > The full terminal transcript is attached
>      >      > Regards,
>      >      >    Andrew
>      >      > _______________________________________________
>      >      > users mailing list
>      >      > users at rtems.org
>      >      > http://lists.rtems.org/mailman/listinfo/users
