riscv target spec for newlib and rtems
Matt Wette matt.wette at gmail.com
Thu Dec 28 13:58:59 UTC 2023
The v5 source-builder does not work on python3 machines and current
RTEMS release is 5.2 (or 5.1 if you go to www.rtems.org.   I did find
v6.1-rc1  by guessing the path based on the 5.1 release path. I decided
to take a shot at building on my own.   I've done this sort of thing
before (e.g., building gcc 1.43 for VxWorks on 68k machines back in the
'90s, before the days of autotools).   And, I wanted to see if I could
get a guix build going.
I'll try the 6.1-rc1 also.
Thanks for the info
Matt
On 12/27/23 4:06 PM, Joel Sherrill wrote:
> Sounds like you are trying to do this by hand. The RTEMS Source
> Builder (RSB) is the recommended way to build tools. See
> https://docs.rtems.org/branches/master/user/index.html for detailed
> instructions on the required packages on your host and how to use the
> RSB.
> The RSB fetches, patches, and builds the recommended tool versions.
> Not that you need it with the RSB building everything for you but the
> target should be riscv-rtems6.
> On Wed, Dec 27, 2023, 5:43 PM Matt Wette <matt.wette at gmail.com> wrote:
>     Hi All,
>     I'm working on compiling binutils, gcc, newlib and rtems-5.3 for
>     RISC-V.   What is appropriate target-spec?
>     I've searched for specification hints but can't anything.
>     Currently, I'm
>     using riscv-rtems-elf but it seems
>     newlib and rtems want to see a target spec with four fields and
>     rtems is
>     #3 or #4 in the list.
>     Any references for this?
>     for reference, using binutils-2.38, gcc-12.3.0 and
>     newlib-4.3.0.20230120
>     I've gotten binutils, gcc and newlib to build (with patch to deal
>     with
>     above config issue on newlib).
>     Matt
>     _______________________________________________
>     users mailing list
>     users at rtems.org
>     http://lists.rtems.org/mailman/listinfo/users
URL: <http://lists.rtems.org/pipermail/users/attachments/20231228/d92b40c3/attachment.htm>
