Error in building rtems 5.3 tools via mingw
Giovanni Righi righiqwe at gmail.com
Wed Mar 29 07:33:34 UTC 2023
I tried again with the flag --jobs=1 on a clean build and I got the same
error message.
But this time it seems to happen on the second file. My idea is that with
parallel building it managed to build more files before getting the error,
while with only one job it's slower so it gets the error earlier.
Here's the tail of the log:
___________________________________________________________________________________
+ ./waf distclean configure --prefix=/c/opt/rtems/5.3
'distclean' finished successfully (0.000s)
Setting top to                           :
C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3
Setting out to                           :
C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/build
Version                                  : 5.3 (5)
Checking for program 'python'            : C:/msys64/mingw64/bin/python.exe
Checking for python version >= 2.6.6     : 3.10.10
Checking for program 'python2'           :
C:\msys64\mingw64\bin/python2.exe
Checking for program 'python3'           :
C:\msys64\mingw64\bin/python3.exe
Checking for 'gcc' (C compiler)          : C:\msys64\mingw64\bin/gcc.exe
Checking for 'g++' (C++ compiler)        : C:\msys64\mingw64\bin/g++.exe
Checking for header alloca.h             : not found
Checking for header fcntl.h              : yes
Checking for header process.h            : yes
Checking for header stdlib.h             : yes
Checking for header string.h             : yes
Checking for header strings.h            : yes
Checking for header sys/file.h           : yes
Checking for header sys/stat.h           : yes
Checking for header sys/time.h           : yes
Checking for header sys/types.h          : yes
Checking for header sys/wait.h           : not found
Checking for header unistd.h             : yes
Checking for header vfork.h              : not found
Checking for getrusage                   : no
Checking for program 'm4'                : C:\msys64\usr\bin/m4.exe
Checking for kill                        : no
Checking for strnlen                     : yes
Checking for fopen64                     : no
Checking for stat64                      : yes
Checking for library LLVM                : not found
Checking for header zlib.h               : yes
Checking for library z                   : yes
Checking for library ws2_32              : yes
Checking for compiler flags -std=c++14   : yes
'configure' finished successfully (12.090s)
+ ./waf
Waf: Entering directory
`C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/build'
[  1/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_convert.m4
Traceback (most recent call last):
  File "<string>", line 55, in <module>
  File "<string>", line 20, in run
[  2/258] Compiling rtemstoolkit/elftoolchain/libelf/libelf_fsize.m4
OSError: [Errno 22] Invalid argument
Waf: Leaving directory
Build failed
  File
"C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py",
line 181, in exec_command
    ret,out,err=Utils.run_process(cmd,kw,cargs)
  File
"C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Utils.py",
line 598, in run_process
    return run_prefork_process(cmd,kwargs,cargs)
  File
line 533, in run_prefork_process
    proc.stdin.write(obj)
BrokenPipeError: [Errno 32] Broken pipe
During handling of the above exception, another exception occurred:
  File
"C:/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/rtems-tools-5.3/waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Task.py",
line 180, in process
    ret=self.run()
  File "<string>", line 14, in f
  File
line 173, in exec_command
    return self.generator.bld.exec_command(cmd,**kw)
  File
line 183, in exec_command
    raise Errors.WafError('Execution failure: %s'%str(e),ex=e)
waflib.Errors.WafError: Execution failure: [Errno 32] Broken pipe
shell cmd failed: sh -ex
 /c/opt/rtems/rtems-source-builder-5.3/rtems/build/rt51/do-build
error: building rt51
Il giorno sab 25 mar 2023 alle ore 00:06 Chris Johns <chrisj at rtems.org> ha
scritto:
> On 23/3/2023 10:48 pm, Giovanni Righi wrote:
> > Ok so I tried what you suggested, I downloaded the rtems-tools-5.3 tar
> form the
> > server and I launched directly the waf script.
> > I got the same error, then I tried again and again I got the same error
> but on a
> > file following the one that caused the first error. So I launched the
> waf again
> > and it managed to compile all the files.
> > After this I did a waf clean and tried again and I got the same results,
> error -
> > error - compilation complete.
> > Note the two errors happened in the same files as the first "run".
> > So now I have the tools compiled but I don't know how to finish the
> build of the
> > toolchain, because if I launch the sb-set-builder again it cleans
> everything and
> > starts again so when it reaches the tools part it crashes again because
> of the
> > waf error.
> > I hope the explanation is clear and there is a solution for this
> problem.
> > I attach a file with parts of the three runs so you can see what's going
> on.
> Thanks. I wonder if the scripting used to handle the `.m4` files is broken
> on
> mingw? What happens if you add --jobs=1 to a clean build?
> What version of Windows?
> Chris
URL: <http://lists.rtems.org/pipermail/users/attachments/20230329/c006027c/attachment.htm>
