rtems6 master on darwin-x86_64 fails building: arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1
Heinz Junkes junkes at fhi-berlin.mpg.de
Wed Oct 18 12:31:38 UTC 2023
Leider gibt es da noch andere Probleme?
I have now tried to build with gcc-10 and rsb-master:
../source-builder/sb-set-builder --prefix=${RTEMS_ROOT} --with-rtems-gcc=tools/rtems-gcc-10-newlib-head.cfg 6/rtems-arm
/bin/sh ../../libtool --tag CXX --tag disable-shared   --mode=compile /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/./gcc/xgcc -shared-libgcc -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/./gcc -nostdinc++ -L/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/src -L/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/src/.libs -L/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/libsupc++/.libs -nostdinc -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/newlib/ -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/newlib/targ-include -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/gnu-mirror-gcc-d04fe55/newlib/libc/include -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/bin/ -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/lib/ -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/include -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/sys-include    -I/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/gnu-mirror-gcc-d04fe55/libstdc++-v3/../libgcc -I/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/arm-rtems6 -I/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include -I/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/gnu-mirror-gcc-d04fe55/libstdc++-v3/libsupc++   -std=gnu++11   -fno-implicit-templates  -Wall -Wextra -Wwrite-strings -Wcast-qual -Wabi=2  -fdiagnostics-show-location=once   -ffunction-sections -fdata-sections  -frandom-seed=system_error.lo -g -O2  -c -o system_error.lo ../../../../../gnu-mirror-gcc-d04fe55/libstdc++-v3/src/c++11/system_error.cc
In file included from /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/random:51,
                 from ../../../../../gnu-mirror-gcc-d04fe55/libstdc++-v3/src/c++11/random.cc:28:
/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/bits/random.tcc: In function '_RealType std::generate_canonical(_UniformRandomNumberGenerator&)':
/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/bits/random.tcc:3296:54:   in 'constexpr' expansion of 'std::log(2.0e+0l)'
/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/bits/random.tcc:3296:44: internal compiler error: Segmentation fault: 11
 3296 |       const size_t __log2r = std::log(__r) / std::log(2.0L);
libbacktrace could not find executable to open
Please submit a full bug report,
with preprocessed source if appropriate.
See <https://gcc.gnu.org/bugs/> for instructions.
Sorry,
Heinz
> On 18. Oct 2023, at 12:48, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 18.10.23 12:29, Heinz Junkes wrote:
>> unfortunately also with the GCC 13.2 configuration still the same error: nclude -g -O2 -mthumb -O2 -I../../../../gcc-13.2.0/libgcc/../newlib/libc/sys/rtems/include -g -O2 -DIN_GCC -DCROSS_DIRECTORY_STRUCTURE -W -Wall -Wno-narrowing -Wwrite-strings -Wcast-qual -Wstrict-prototypes -Wmissing-prototypes -Wold-style-definition -isystem ./include -fno-inline -g -DIN_LIBGCC2 -fbuilding-libgcc -fno-stack-protector -Dinhibit_libc -fno-inline -I. -I. -I../../.././gcc -I../../../../gcc-13.2.0/libgcc -I../../../../gcc-13.2.0/libgcc/. -I../../../../gcc-13.2.0/libgcc/../gcc -I../../../../gcc-13.2.0/libgcc/../include -DHAVE_CC_TLS -o _divtc3.o -MT _divtc3.o -MD -MP -MF _divtc3.dep -DL_divtc3 -c ../../../../gcc-13.2.0/libgcc/libgcc2.c -fvisibility=hidden -DHIDE_EXPORTS ../../../../gcc-13.2.0/libgcc/libgcc2.c: In function '__divdc3': ../../../../gcc-13.2.0/libgcc/libgcc2.c:2063:7: internal compiler error: Segmentation fault: 11 2063 | if (FABS (d) >= RBIG) | ^~ Please submit a full bug report, with preprocessed source (by using -freport-bug). See <https://gcc.gnu.org/bugs/> for instructions. make[4]: *** [_divdc3.o] Error 1
> Ok, great. At least it is consistent. Maybe GCC 10 works.
> This bug should be reported to the GCC project.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
