rtems6 master on darwin-x86_64 fails building: arm-rtems6-gcc-814ec21-newlib-fbc5496-x86_64-apple-darwin22.6.0-1
Heinz Junkes junkes at fhi-berlin.mpg.de
Thu Oct 19 06:16:07 UTC 2023
Good morning Sebastian,
when I use 7/rtems-arm it does not get better unfortunately :
[junkes at h XILINX_ZYNQ_A9_QEMU]$ tail -1000 ./rsb/rtems/rsb-report-arm-rtems7-gdb-29736fc-x86_64-apple-darwin22.6.0-1.txt
RTEMS Tools Project - Source Builder Error Report
 Build: error: building arm-rtems7-gdb-29736fc-x86_64-apple-darwin22.6.0-1
 Command Line: ../source-builder/sb-set-builder --prefix=/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6 7/rtems-arm
 Python: 3.9.12 (main, Apr  5 2022, 01:53:17) [Clang 12.0.0 ]
 git://git.rtems.org/rtems-source-builder.git/origin/633023de6517998ee3b84e7ed172b1c5f2bf502b
 Darwin h.rz-berlin.mpg.de 22.6.0 Darwin Kernel Version 22.6.0: Fri Sep 15 13:39:52 PDT 2023; root:xnu-8796.141.3.700.8~1/RELEASE_X86_64 x86_64
Tail of the build log:
__deprecated_msg("This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead.")
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/sys/cdefs.h:215:48: note: expanded from macro '__deprecated_msg'
        #define __deprecated_msg(_msg) __attribute__((__deprecated__(_msg)))
../../sourceware-mirror-binutils-gdb-29736fc/gdb/dwarf2/read.c:5685:5: warning: 'sprintf' is deprecated: This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead. [-Wdeprecated-declarations]
                  sprintf (buf, "CU at offset %s",
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/stdio.h:180:1: note: 'sprintf' has been explicitly marked deprecated here
../../sourceware-mirror-binutils-gdb-29736fc/gdb/elfread.c:831:3: warning: 'sprintf' is deprecated: This function is provided for compatibility reasons only.  Due to security concerns inherent in the design of sprintf(3), it is highly recommended that you use snprintf(3) instead. [-Wdeprecated-declarations]
  sprintf (name_got_plt, "%s" SYMBOL_GOT_PLT_SUFFIX, name);
  CXX    unittests/search-memory-selftests.o
  CXX    unittests/string_view-selftests.o
In file included from ../../sourceware-mirror-binutils-gdb-29736fc/gdb/unittests/string_view-selftests.c:35:
In file included from ../../sourceware-mirror-binutils-gdb-29736fc/gdb/defs.h:26:
In file included from ../../sourceware-mirror-binutils-gdb-29736fc/gdb/../gdbsupport/common-defs.h:92:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/c++/v1/cstdlib:87:
In file included from ../gnulib/import/stdlib.h:100:
In file included from ../gnulib/import/unistd.h:40:
In file included from /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/unistd.h:639:
../gnulib/import/sys/select.h:797:19: error: declaration of 'select' has a different language linkage
_GL_CXXALIASWARN (select);
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX.sdk/usr/include/sys/_select.h:43:10: note: previous declaration is here
int      select(int, fd_set * __restrict, fd_set * __restrict,
  CXX    unittests/style-selftests.o
  CXX    unittests/tracepoint-selftests.o
  CXX    unittests/tui-selftests.o
1 error generated.
make[2]: *** [unittests/string_view-selftests.o] Error 1
make[2]: *** Waiting for unfinished jobs....
make[1]: *** [all-gdb] Error 2
make: *** [all] Error 2
shell cmd failed: /bin/sh -ex  /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems7-gdb-29736fc-x86_64-apple-darwin22.6.0-1/do-build
Heinz
> On 18. Oct 2023, at 15:23, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 18.10.23 14:31, Heinz Junkes wrote:
>> Leider gibt es da noch andere Probleme?
>> I have now tried to build with gcc-10 and rsb-master:
>> ../source-builder/sb-set-builder --prefix=${RTEMS_ROOT} --with-rtems-gcc=tools/rtems-gcc-10-newlib-head.cfg 6/rtems-arm
>> /bin/sh ../../libtool --tag CXX --tag disable-shared   --mode=compile /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/./gcc/xgcc -shared-libgcc -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/./gcc -nostdinc++ -L/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/src -L/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/src/.libs -L/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/libsupc++/.libs -nostdinc -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/newlib/ -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/newlib/targ-include -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/gnu-mirror-gcc-d04fe55/newlib/libc/include -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/bin/ -B/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/lib/ -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/include -isystem /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rtems/6/arm-rtems6/sys-include    -I/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/gnu-mirror-gcc-d04fe55/libstdc++-v3/../libgcc -I/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/arm-rtems6 -I/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include -I/Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/gnu-mirror-gcc-d04fe55/libstdc++-v3/libsupc++   -std=gnu++11   -fno-implicit-templates  -Wall -Wextra -Wwrite-strings -Wcast-qual -Wabi=2  -fdiagnostics-show-location=once   -ffunction-sections -fdata-sections  -frandom-seed=system_error.lo -g -O2  -c -o system_error.lo ../../../../../gnu-mirror-gcc-d04fe55/libstdc++-v3/src/c++11/system_error.cc
>> In file included from /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/random:51,
>>                  from ../../../../../gnu-mirror-gcc-d04fe55/libstdc++-v3/src/c++11/random.cc:28:
>> /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/bits/random.tcc: In function '_RealType std::generate_canonical(_UniformRandomNumberGenerator&)':
>> /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/bits/random.tcc:3296:54:   in 'constexpr' expansion of 'std::log(2.0e+0l)'
>> /Volumes/RTEMS_DEV/XILINX_ZYNQ_A9_QEMU/rsb/rtems/build/arm-rtems6-gcc-d04fe55-newlib-fbc5496-x86_64-apple-darwin22.6.0-1/build/arm-rtems6/libstdc++-v3/include/bits/random.tcc:3296:44: internal compiler error: Segmentation fault: 11
>>  3296 |       const size_t __log2r = std::log(__r) / std::log(2.0L);
>> libbacktrace could not find executable to open
>> Please submit a full bug report,
>> with preprocessed source if appropriate.
>> See <https://gcc.gnu.org/bugs/> for instructions.
> So, GCC 10, 12, and 13 don't work on this macOS version. I updated the RTEMS 7 tools (GCC 14) right now, maybe this works:
> ../source-builder/sb-set-builder --prefix=${RTEMS_ROOT} 7/rtems-arm
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
