Stack allocator change was Re: change log for rtems (2011-12-14)
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Dec 14 14:06:33 UTC 2011
This change necessitates changes to doc/user/conf.t
and adds a user visible configuration change that needs
to be noted in the evolving 4.11 release notes:
http://www.rtems.org/wiki/index.php/4.11_Release_Notes
--joel
On 12/14/2011 07:31 AM, rtems-vc at rtems.org wrote:
> *sh*
> 2011-12-14 Sebastian Huber<sebastian.huber at embedded-brains.de>
> PR 1924/cpukit
> * sapi/include/rtems/config.h: Added stack_allocate_init_hook to
> rtems_configuration_table.
> * sapi/include/confdefs.h: Added CONFIGURE_TASK_STACK_FROM_ALLOCATOR
> and CONFIGURE_TASK_STACK_ALLOCATOR_INIT defines. Set default stack
> allocator and free hook to _Workspace_Allocate() and _Workspace_Free()
> respectively.
> * score/src/thread.c, score/src/threadstackallocate.c,
> score/src/threadstackfree.c: Update due to API changes.
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/cpukit/ChangeLog.diff?r1=text&tr1=1.3093&r2=text&tr2=1.3094&diff_format=h>
> 1.3094 cpukit/ChangeLog
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/cpukit/sapi/include/confdefs.h.diff?r1=text&tr1=1.178&r2=text&tr2=1.179&diff_format=h>
> 1.179 cpukit/sapi/include/confdefs.h
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/cpukit/sapi/include/rtems/config.h.diff?r1=text&tr1=1.57&r2=text&tr2=1.58&diff_format=h>
> 1.58 cpukit/sapi/include/rtems/config.h
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/cpukit/score/src/thread.c.diff?r1=text&tr1=1.68&r2=text&tr2=1.69&diff_format=h>
> 1.69 cpukit/score/src/thread.c
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/cpukit/score/src/threadstackallocate.c.diff?r1=text&tr1=1.15&r2=text&tr2=1.16&diff_format=h>
> 1.16 cpukit/score/src/threadstackallocate.c
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/cpukit/score/src/threadstackfree.c.diff?r1=text&tr1=1.8&r2=text&tr2=1.9&diff_format=h>
> 1.9 cpukit/score/src/threadstackfree.c
> diff -u rtems/cpukit/ChangeLog:1.3093 rtems/cpukit/ChangeLog:1.3094
> --- rtems/cpukit/ChangeLog:1.3093 Wed Dec 14 03:22:42 2011
> +++ rtems/cpukit/ChangeLog Wed Dec 14 07:17:18 2011
> @@ -1,5 +1,17 @@
> + PR 1924/cpukit
> + * sapi/include/rtems/config.h: Added stack_allocate_init_hook to
> + rtems_configuration_table.
> + * sapi/include/confdefs.h: Added CONFIGURE_TASK_STACK_FROM_ALLOCATOR
> + and CONFIGURE_TASK_STACK_ALLOCATOR_INIT defines. Set default stack
> + allocator and free hook to _Workspace_Allocate() and _Workspace_Free()
> + respectively.
> + * score/src/thread.c, score/src/threadstackallocate.c,
> + score/src/threadstackfree.c: Update due to API changes.
> +2011-12-14 Sebastian Huber<sebastian.huber at embedded-brains.de>
> * libcsupport/src/termios_setinitialbaud.c: Fixed typo.
> diff -u rtems/cpukit/sapi/include/confdefs.h:1.178 rtems/cpukit/sapi/include/confdefs.h:1.179
> --- rtems/cpukit/sapi/include/confdefs.h:1.178 Tue Dec 13 08:37:03 2011
> +++ rtems/cpukit/sapi/include/confdefs.h Wed Dec 14 07:17:19 2011
> @@ -44,6 +44,7 @@
> #include<rtems.h>
> #include<rtems/score/apimutex.h>
> +#include<rtems/score/wkspace.h>
> #ifdef __cplusplus
> extern "C" {
> @@ -823,17 +824,24 @@
> #endif
> - * Configure the very much optional task stack allocator
> + * Configure the very much optional task stack allocator initialization
> -#ifndef CONFIGURE_TASK_STACK_ALLOCATOR
> - #define CONFIGURE_TASK_STACK_ALLOCATOR NULL
> +#ifndef CONFIGURE_TASK_STACK_ALLOCATOR_INIT
> + #define CONFIGURE_TASK_STACK_ALLOCATOR_INIT NULL
> #endif
> - * Configure the very much optional task stack deallocator
> + * Configure the very much optional task stack allocator and deallocator.
> -#ifndef CONFIGURE_TASK_STACK_DEALLOCATOR
> - #define CONFIGURE_TASK_STACK_DEALLOCATOR NULL
> +#if !defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
> +&& !defined(CONFIGURE_TASK_STACK_DEALLOCATOR)
> + #define CONFIGURE_TASK_STACK_ALLOCATOR _Workspace_Allocate
> + #define CONFIGURE_TASK_STACK_DEALLOCATOR _Workspace_Free
> +#elif (defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
> +&& !defined(CONFIGURE_TASK_STACK_DEALLOCATOR)) \
> + || (!defined(CONFIGURE_TASK_STACK_ALLOCATOR) \
> +&& defined(CONFIGURE_TASK_STACK_DEALLOCATOR))
> + #error "CONFIGURE_TASK_STACK_ALLOCATOR and CONFIGURE_TASK_STACK_DEALLOCATOR must be both defined or both undefined"
> #endif
> @@ -869,7 +877,6 @@
> #endif
> #ifdef CONFIGURE_UNIFIED_WORK_AREAS
> - #include<rtems/score/wkspace.h>
> Heap_Control *RTEMS_Malloc_Heap =&_Workspace_Area;
> #else
> Heap_Control RTEMS_Malloc_Area;
> @@ -929,6 +936,19 @@
> (ssize_t)((_size) + HEAP_BLOCK_HEADER_SIZE + CPU_HEAP_ALIGNMENT - 1)
> + * This is a helper macro used in stack space calculations in this file. It
> + * may be provided by the application in case a special task stack allocator
> + * is used. The default is allocation from the RTEMS Workspace.
> +#ifdef CONFIGURE_TASK_STACK_FROM_ALLOCATOR
> + #define _Configure_From_stackspace(_stack_size) \
> + CONFIGURE_TASK_STACK_FROM_ALLOCATOR(_stack_size)
> +#else
> + _Configure_From_workspace(_stack_size)
> +#endif
> * Do not use the unlimited bit as part of the multiplication
> * for memory usage.
> @@ -2051,23 +2071,23 @@
> #define CONFIGURE_IDLE_TASKS_STACK \
> (CONFIGURE_IDLE_TASKS_COUNT * \
> - _Configure_From_workspace( CONFIGURE_IDLE_TASK_STACK_SIZE ) )
> + _Configure_From_stackspace( CONFIGURE_IDLE_TASK_STACK_SIZE ) )
> #define CONFIGURE_TASKS_STACK \
> (_Configure_Max_Objects( CONFIGURE_MAXIMUM_TASKS ) * \
> - _Configure_From_workspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) )
> + _Configure_From_stackspace( CONFIGURE_MINIMUM_TASK_STACK_SIZE ) )
> #define CONFIGURE_POSIX_THREADS_STACK \
> (_Configure_Max_Objects( CONFIGURE_MAXIMUM_POSIX_THREADS ) * \
> - _Configure_From_workspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
> + _Configure_From_stackspace( CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE ) )
> #define CONFIGURE_GOROUTINES_STACK \
> (_Configure_Max_Objects( CONFIGURE_MAXIMUM_GOROUTINES ) * \
> #define CONFIGURE_ADA_TASKS_STACK \
> (_Configure_Max_Objects( CONFIGURE_MAXIMUM_ADA_TASKS ) * \
> #else /* CONFIGURE_EXECUTIVE_RAM_SIZE */
> @@ -2180,6 +2200,7 @@
> CONFIGURE_IDLE_TASK_BODY, /* user's IDLE task */
> CONFIGURE_IDLE_TASK_STACK_SIZE, /* IDLE task stack size */
> CONFIGURE_INTERRUPT_STACK_SIZE, /* interrupt stack size */
> + CONFIGURE_TASK_STACK_ALLOCATOR_INIT, /* stack allocator init */
> CONFIGURE_TASK_STACK_ALLOCATOR, /* stack allocator */
> CONFIGURE_TASK_STACK_DEALLOCATOR, /* stack deallocator */
> CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY, /* true to clear memory */
> diff -u rtems/cpukit/sapi/include/rtems/config.h:1.57 rtems/cpukit/sapi/include/rtems/config.h:1.58
> --- rtems/cpukit/sapi/include/rtems/config.h:1.57 Thu Nov 10 08:40:13 2011
> +++ rtems/cpukit/sapi/include/rtems/config.h Wed Dec 14 07:17:19 2011
> @@ -84,6 +84,30 @@
> } rtems_multiprocessing_table;
> #endif
> + * @brief Task stack allocator initialization hook.
> + * @param[in] stack_space_size Size of the stack space in bytes.
> +typedef void (*rtems_stack_allocate_init_hook)( size_t stack_space_size );
> + * @brief Task stack allocator hook.
> + * @param[in] stack_size Size of the task stack in bytes.
> + * @retval NULL Not enough memory.
> + * @retval other Pointer to task stack.
> +typedef void *(*rtems_stack_allocate_hook)( size_t stack_size );
> + * @brief Task stack deallocator hook.
> + * @param[in] addr Pointer to previously allocated task stack.
> +typedef void (*rtems_stack_free_hook)( void *addr );
> * The following records define the Configuration Table. The
> * information contained in this table is required in all
> @@ -139,15 +163,20 @@
> uint32_t interrupt_stack_size;
> - /** The BSP may want to provide it's own stack allocation routines.
> - * In this case, the BSP will provide this stack allocation hook.
> + * @brief Optional task stack allocator initialization hook.
> - void * (*stack_allocate_hook)( size_t );
> + rtems_stack_allocate_init_hook stack_allocate_init_hook;
> - /** The BSP may want to provide it's own stack free routines.
> - * In this case, the BSP will provide this stack free hook.
> + * @brief Optional task stack allocator hook.
> - void (*stack_free_hook)( void *);
> + rtems_stack_allocate_hook stack_allocate_hook;
> + * @brief Optional task stack free hook.
> + rtems_stack_free_hook stack_free_hook;
> /** If this element is TRUE, then RTEMS will zero the Executive Workspace.
> * When this element is FALSE, it is assumed that the BSP or invoking
> @@ -268,6 +297,9 @@
> #define rtems_configuration_get_interrupt_stack_size() \
> (Configuration.interrupt_stack_size)
> +#define rtems_configuration_get_stack_allocate_init_hook() \
> + (Configuration.stack_allocate_init_hook)
> #define rtems_configuration_get_stack_allocate_hook() \
> (Configuration.stack_allocate_hook)
> diff -u rtems/cpukit/score/src/thread.c:1.68 rtems/cpukit/score/src/thread.c:1.69
> --- rtems/cpukit/score/src/thread.c:1.68 Mon Apr 4 11:40:00 2011
> +++ rtems/cpukit/score/src/thread.c Wed Dec 14 07:17:19 2011
> @@ -49,30 +49,29 @@
> void _Thread_Handler_initialization(void)
> - uint32_t ticks_per_timeslice;
> - uint32_t maximum_extensions;
> + uint32_t ticks_per_timeslice =
> + rtems_configuration_get_ticks_per_timeslice();
> + uint32_t maximum_extensions =
> + rtems_configuration_get_maximum_extensions();
> + rtems_stack_allocate_init_hook stack_allocate_init_hook =
> + rtems_configuration_get_stack_allocate_init_hook();
> uint32_t maximum_internal_threads;
> #if defined(RTEMS_MULTIPROCESSING)
> - uint32_t maximum_proxies;
> + uint32_t maximum_proxies =
> + _Configuration_MP_table->maximum_proxies;
> #endif
> - ticks_per_timeslice = Configuration.ticks_per_timeslice;
> - maximum_extensions = Configuration.maximum_extensions;
> - #if defined(RTEMS_MULTIPROCESSING)
> - maximum_proxies = _Configuration_MP_table->maximum_proxies;
> - #endif
> - * BOTH stacks hooks must be set or both must be NULL.
> - * Do not allow mixture.
> - if ( !( (!Configuration.stack_allocate_hook)
> - == (!Configuration.stack_free_hook) ) )
> + if ( rtems_configuration_get_stack_allocate_hook() == NULL ||
> + rtems_configuration_get_stack_free_hook() == NULL)
> _Internal_error_Occurred(
> INTERNAL_ERROR_CORE,
> true,
> INTERNAL_ERROR_BAD_STACK_HOOK
> + if ( stack_allocate_init_hook != NULL )
> + (*stack_allocate_init_hook)( rtems_configuration_get_stack_space_size() );
> _Thread_Dispatch_necessary = false;
> _Thread_Executing = NULL;
> _Thread_Heir = NULL;
> diff -u rtems/cpukit/score/src/threadstackallocate.c:1.15 rtems/cpukit/score/src/threadstackallocate.c:1.16
> --- rtems/cpukit/score/src/threadstackallocate.c:1.15 Sun Jul 24 18:55:14 2011
> +++ rtems/cpukit/score/src/threadstackallocate.c Wed Dec 14 07:17:19 2011
> @@ -46,33 +46,24 @@
> void *stack_addr = 0;
> size_t the_stack_size;
> + rtems_stack_allocate_hook stack_allocate_hook =
> + rtems_configuration_get_stack_allocate_hook();
> the_stack_size = _Stack_Ensure_minimum( stack_size );
> - * Call ONLY the CPU table stack allocate hook, _or_ the
> - * the RTEMS workspace allocate. This is so the stack free
> - * routine can call the correct deallocation routine.
> + * Pad the requested size so we allocate enough memory
> + * so the context initialization can align it properly. The address
> + * returned the workspace allocate must be directly stored in the
> + * stack control block because it is later used in the free sequence.
> + * Thus it is the responsibility of the CPU dependent code to
> + * get and keep the stack adjust factor, the stack alignment, and
> + * the context initialization sequence in sync.
> + the_stack_size = _Stack_Adjust_size( the_stack_size );
> - if ( Configuration.stack_allocate_hook ) {
> - stack_addr = (*Configuration.stack_allocate_hook)( the_stack_size );
> - } else {
> - * First pad the requested size so we allocate enough memory
> - * so the context initialization can align it properly. The address
> - * returned the workspace allocate must be directly stored in the
> - * stack control block because it is later used in the free sequence.
> - * Thus it is the responsibility of the CPU dependent code to
> - * get and keep the stack adjust factor, the stack alignment, and
> - * the context initialization sequence in sync.
> - the_stack_size = _Stack_Adjust_size( the_stack_size );
> - stack_addr = _Workspace_Allocate( the_stack_size );
> + stack_addr = (*stack_allocate_hook)( the_stack_size );
> if ( !stack_addr )
> the_stack_size = 0;
> diff -u rtems/cpukit/score/src/threadstackfree.c:1.8 rtems/cpukit/score/src/threadstackfree.c:1.9
> --- rtems/cpukit/score/src/threadstackfree.c:1.8 Fri Jan 28 14:24:54 2011
> +++ rtems/cpukit/score/src/threadstackfree.c Wed Dec 14 07:17:19 2011
> @@ -41,6 +41,9 @@
> Thread_Control *the_thread
> + rtems_stack_free_hook stack_free_hook =
> + rtems_configuration_get_stack_free_hook();
> #if defined(RTEMS_SCORE_THREAD_ENABLE_USER_PROVIDED_STACK_VIA_API)
> * If the API provided the stack space, then don't free it.
> @@ -55,8 +58,5 @@
> * routine properly matches the allocation of the stack.
> - if ( Configuration.stack_free_hook )
> - (*Configuration.stack_free_hook)( the_thread->Start.Initial_stack.area );
> - else
> - _Workspace_Free( the_thread->Start.Initial_stack.area );
> + (*stack_free_hook)( the_thread->Start.Initial_stack.area );
> *sh*
> PR 1924/cpukit
> * spstkalloc02/.cvsignore, spstkalloc02/Makefile.am,
> spstkalloc02/init.c, spstkalloc02/spstkalloc02.doc,
> spstkalloc02/spstkalloc02.scn: New files.
> * Makefile.am, configure.ac: Reflect changes above.
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/ChangeLog.diff?r1=text&tr1=1.503&r2=text&tr2=1.504&diff_format=h>
> 1.504 testsuites/sptests/ChangeLog
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/Makefile.am.diff?r1=text&tr1=1.117&r2=text&tr2=1.118&diff_format=h>
> 1.118 testsuites/sptests/Makefile.am
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/configure.ac.diff?r1=text&tr1=1.124&r2=text&tr2=1.125&diff_format=h>
> 1.125 testsuites/sptests/configure.ac
> A
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/spstkalloc02/.cvsignore?rev=1.1&content-type=text/vnd.viewcvs-markup>
> 1.1 testsuites/sptests/spstkalloc02/.cvsignore
> A
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/spstkalloc02/Makefile.am?rev=1.1&content-type=text/vnd.viewcvs-markup>
> 1.1 testsuites/sptests/spstkalloc02/Makefile.am
> A
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/spstkalloc02/init.c?rev=1.1&content-type=text/vnd.viewcvs-markup>
> 1.1 testsuites/sptests/spstkalloc02/init.c
> A
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/spstkalloc02/spstkalloc02.doc?rev=1.1&content-type=text/vnd.viewcvs-markup>
> 1.1 testsuites/sptests/spstkalloc02/spstkalloc02.doc
> A
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/spstkalloc02/spstkalloc02.scn?rev=1.1&content-type=text/vnd.viewcvs-markup>
> 1.1 testsuites/sptests/spstkalloc02/spstkalloc02.scn
> diff -u rtems/testsuites/sptests/ChangeLog:1.503 rtems/testsuites/sptests/ChangeLog:1.504
> --- rtems/testsuites/sptests/ChangeLog:1.503 Tue Dec 13 04:02:30 2011
> +++ rtems/testsuites/sptests/ChangeLog Wed Dec 14 07:18:01 2011
> @@ -1,3 +1,11 @@
> + PR 1924/cpukit
> + * spstkalloc02/.cvsignore, spstkalloc02/Makefile.am,
> + spstkalloc02/init.c, spstkalloc02/spstkalloc02.doc,
> + spstkalloc02/spstkalloc02.scn: New files.
> + * Makefile.am, configure.ac: Reflect changes above.
> 2011-12-13 Ralf Corsépius<ralf.corsepius at rtems.org>
> * sp31/task1.c: Make Do_nothing static.
> diff -u rtems/testsuites/sptests/Makefile.am:1.117 rtems/testsuites/sptests/Makefile.am:1.118
> --- rtems/testsuites/sptests/Makefile.am:1.117 Wed Sep 28 11:01:53 2011
> +++ rtems/testsuites/sptests/Makefile.am Wed Dec 14 07:18:01 2011
> @@ -17,7 +17,7 @@
> sp70 sp71 sp72 sp73 sp74 sp75 sp76 sp2038 \
> spassoc01 spchain spclockget spcoverage spobjgetnext \
> spnotepad01 spprintk spprivenv01 sprbtree01 spsize spstkalloc \
> - spthreadq01 spwatchdog spwkspace \
> + spstkalloc02 spthreadq01 spwatchdog spwkspace \
> sperror01 sperror02 sperror03 \
> spfatal01 spfatal02 spfatal03 spfatal04 spfatal05 spfatal06 spfatal07 \
> spfatal08 spfatal09 spfatal10 spfatal11 spfatal12 spfatal13 spfatal14 \
> diff -u rtems/testsuites/sptests/configure.ac:1.124 rtems/testsuites/sptests/configure.ac:1.125
> --- rtems/testsuites/sptests/configure.ac:1.124 Thu Sep 29 20:55:27 2011
> +++ rtems/testsuites/sptests/configure.ac Wed Dec 14 07:18:01 2011
> @@ -180,6 +180,7 @@
> spsimplesched03/Makefile
> spsize/Makefile
> spstkalloc/Makefile
> +spstkalloc02/Makefile
> spthreadq01/Makefile
> spwatchdog/Makefile
> spwkspace/Makefile
> diff -u /dev/null rtems/testsuites/sptests/spstkalloc02/.cvsignore:1.1
> --- /dev/null Wed Dec 14 07:31:33 2011
> +++ rtems/testsuites/sptests/spstkalloc02/.cvsignore Wed Dec 14 07:18:01 2011
> @@ -0,0 +1,2 @@
> +Makefile
> +Makefile.in
> diff -u /dev/null rtems/testsuites/sptests/spstkalloc02/Makefile.am:1.1
> +++ rtems/testsuites/sptests/spstkalloc02/Makefile.am Wed Dec 14 07:18:01 2011
> @@ -0,0 +1,26 @@
> +## $Id$
> +rtems_tests_PROGRAMS = spstkalloc02
> +spstkalloc02_SOURCES = init.c
> +dist_rtems_tests_DATA = spstkalloc02.scn
> +dist_rtems_tests_DATA += spstkalloc02.doc
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> +LINK_OBJS = $(spstkalloc02_OBJECTS)
> +LINK_LIBS = $(spstkalloc02_LDLIBS)
> +spstkalloc02$(EXEEXT): $(spstkalloc02_OBJECTS) $(spstkalloc02_DEPENDENCIES)
> + @rm -f spstkalloc02$(EXEEXT)
> + $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff -u /dev/null rtems/testsuites/sptests/spstkalloc02/init.c:1.1
> +++ rtems/testsuites/sptests/spstkalloc02/init.c Wed Dec 14 07:18:01 2011
> @@ -0,0 +1,162 @@
> + * @file
> + * @ingroup sptests
> + * @brief Test that the task stack allocator works.
> + * Copyright (c) 2011 embedded brains GmbH. All rights reserved.
> + * embedded brains GmbH
> + * Obere Lagerstr. 30
> + * 82178 Puchheim
> + * Germany
> + *<rtems at embedded-brains.de>
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> + * $Id$
> +#ifdef HAVE_CONFIG_H
> + #include "config.h"
> +#endif
> +#include<tmacros.h>
> +#include<stdio.h>
> +#include<inttypes.h>
> +#include<rtems/score/heap.h>
> +#define TASK_COUNT 5
> +#define PAGE_SIZE 1024
> +static Heap_Control task_stack_heap;
> +static void task_stack_init(size_t stack_space_size);
> +static void *task_stack_allocate(size_t stack_size);
> +static void task_stack_free(void *addr);
> +static void print_info(void)
> + Heap_Information_block info;
> + _Heap_Get_information(&task_stack_heap,&info);
> + printf(
> + "used blocks = %" PRIu32 ", "
> + "largest used block = %" PRIu32 ", "
> + "used space = %" PRIu32 "\n"
> + "free blocks = %" PRIu32 ", "
> + "largest free block = %" PRIu32 ", "
> + "free space = %" PRIu32 "\n",
> + info.Used.number,
> + info.Used.largest,
> + info.Used.total,
> + info.Free.number,
> + info.Free.largest,
> + info.Free.total
> +static rtems_task Init(rtems_task_argument argument)
> + rtems_status_code sc = RTEMS_SUCCESSFUL;
> + rtems_name name = rtems_build_name('S', 'T', 'K', 'A');
> + rtems_id id = RTEMS_ID_NONE;
> + int i = 0;
> + puts("\n\n*** POSIX TEST STKALLOC 02 ***");
> + print_info();
> + for (i = 2; i< TASK_COUNT; ++i) {
> + sc = rtems_task_create(
> + name,
> + RTEMS_MINIMUM_PRIORITY,
> + RTEMS_MINIMUM_STACK_SIZE,
> + RTEMS_DEFAULT_MODES,
> + RTEMS_DEFAULT_ATTRIBUTES,
> +&id
> + directive_failed(sc, "rtems_task_create");
> + name,
> + 2 * RTEMS_MINIMUM_STACK_SIZE,
> +&id
> + fatal_directive_status(sc, RTEMS_UNSATISFIED, "rtems_task_create");
> + name,
> +&id
> + print_info();
> + puts("*** END OF POSIX TEST STKALLOC 02 ***");
> + rtems_test_exit(0);
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS TASK_COUNT
> +#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT task_stack_init
> +#define CONFIGURE_TASK_STACK_ALLOCATOR task_stack_allocate
> +#define CONFIGURE_TASK_STACK_DEALLOCATOR task_stack_free
> +#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
> +#define CONFIGURE_TASK_STACK_FROM_ALLOCATOR(stack_size) \
> + ((stack_size) + HEAP_BLOCK_HEADER_SIZE + PAGE_SIZE - 1)
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INIT
> +#include<rtems/confdefs.h>
> +static char task_stack_space
> + [CONFIGURE_TASK_STACK_FROM_ALLOCATOR(CONFIGURE_STACK_SPACE_SIZE)];
> + bool ok = _Heap_Initialize(
> +&task_stack_heap,
> + task_stack_space,
> + sizeof(task_stack_space),
> + PAGE_SIZE
> + rtems_test_assert(stack_space_size == CONFIGURE_STACK_SPACE_SIZE);
> + rtems_test_assert(ok);
> + return _Heap_Allocate(&task_stack_heap, stack_size);
> + _Heap_Free(&task_stack_heap, addr);
> diff -u /dev/null rtems/testsuites/sptests/spstkalloc02/spstkalloc02.doc:1.1
> +++ rtems/testsuites/sptests/spstkalloc02/spstkalloc02.doc Wed Dec 14 07:18:01 2011
> @@ -0,0 +1,19 @@
> +# $Id$
> +# Copyright (c) 2011 embedded brains GmbH.
> +# The license and distribution terms for this file may be
> +# found in the file LICENSE in this distribution or at
> +# http://www.rtems.com/license/LICENSE.
> +This file describes the directives and concepts tested by this test set.
> +test set name: spstkalloc01
> +directives:
> +concepts:
> ++ Ensure that the task stack allocator works.
> diff -u /dev/null rtems/testsuites/sptests/spstkalloc02/spstkalloc02.scn:1.1
> +++ rtems/testsuites/sptests/spstkalloc02/spstkalloc02.scn Wed Dec 14 07:18:01 2011
> @@ -0,0 +1,6 @@
> +*** POSIX TEST STKALLOC 02 ***
> +used blocks = 2, largest used block = 5120, used space = 10240
> +free blocks = 1, largest free block = 20480, free space = 20480
> +used blocks = 6, largest used block = 5120, used space = 30720
> +free blocks = 0, largest free block = 0, free space = 0
> +*** END OF POSIX TEST STKALLOC 02 ***
> *sh*
> Typo.
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/spstkalloc02/init.c.diff?r1=text&tr1=1.1&r2=text&tr2=1.2&diff_format=h>
> 1.2 testsuites/sptests/spstkalloc02/init.c
> M
> <http://www.rtems.com/cgi-bin/viewcvs.cgi//rtems/testsuites/sptests/spstkalloc02/spstkalloc02.scn.diff?r1=text&tr1=1.1&r2=text&tr2=1.2&diff_format=h>
> 1.2 testsuites/sptests/spstkalloc02/spstkalloc02.scn
> diff -u rtems/testsuites/sptests/spstkalloc02/init.c:1.1 rtems/testsuites/sptests/spstkalloc02/init.c:1.2
> --- rtems/testsuites/sptests/spstkalloc02/init.c:1.1 Wed Dec 14 07:18:01 2011
> +++ rtems/testsuites/sptests/spstkalloc02/init.c Wed Dec 14 07:19:52 2011
> @@ -74,7 +74,7 @@
> int i = 0;
> - puts("\n\n*** POSIX TEST STKALLOC 02 ***");
> + puts("\n\n*** TEST STKALLOC 02 ***");
> print_info();
> @@ -112,7 +112,7 @@
> print_info();
> - puts("*** END OF POSIX TEST STKALLOC 02 ***");
> + puts("*** END OF TEST STKALLOC 02 ***");
> rtems_test_exit(0);
> diff -u rtems/testsuites/sptests/spstkalloc02/spstkalloc02.scn:1.1 rtems/testsuites/sptests/spstkalloc02/spstkalloc02.scn:1.2
> --- rtems/testsuites/sptests/spstkalloc02/spstkalloc02.scn:1.1 Wed Dec 14 07:18:01 2011
> +++ rtems/testsuites/sptests/spstkalloc02/spstkalloc02.scn Wed Dec 14 07:19:52 2011
> @@ -1,6 +1,6 @@
> -*** POSIX TEST STKALLOC 02 ***
> +*** TEST STKALLOC 02 ***
> -*** END OF POSIX TEST STKALLOC 02 ***
> +*** END OF TEST STKALLOC 02 ***
> Generated by Deluxe Loginfo
> <http://www.codewiz.org/projects/index.html#loginfo> 2.122 by Bernardo
> Innocenti <bernie at develer.com>
Joel Sherrill, Ph.D. Director of Research& Development
