Stack allocator change was Re: change log for rtems (2011-12-14)
Ralf Corsepius ralf.corsepius at rtems.org
Wed Dec 14 14:37:40 UTC 2011
On 12/14/2011 03:33 PM, Joel Sherrill wrote:
> On 12/14/2011 08:19 AM, Sebastian Huber wrote:
>> On 12/14/2011 03:06 PM, Joel Sherrill wrote:
>>> This change necessitates changes to doc/user/conf.t
>>> and adds a user visible configuration change that needs
>>> to be noted in the evolving 4.11 release notes:
>>> http://www.rtems.org/wiki/index.php/4.11_Release_Notes
>> I write the documentation currently. The conf.t is quite out of sync.
> If you have a list of things to fix, please file a PR with them. It is
> challenging to keep up. I have updated it a lot.
>> Can I build the doc outside the source tree?
> Yes. It worked for me when I committed the patches that moved
> us to texi2html
Actually, building out of the source tree is the nominal way to build
it. The fact it also builds inside of the source-tree is just a by-product.
Ralf
