change log for rtems (2011-12-10)
Ralf Corsepius ralf.corsepius at rtems.org
Tue Dec 13 05:19:49 UTC 2011
On 12/12/2011 10:53 PM, Chris Johns wrote:
> On 10/12/11 5:16 PM, rtems-vc at rtems.org wrote:
>> *ralf*
>> 2011-12-10 Ralf Corsépius<ralf.corsepius at rtems.org>
>> * configure.ac (CFLAGS): Add -Wmissing-prototypes.
>> # Append warning flags if CFLAGS wasn't set.
>> AS_IF([test "$GCC" = yes&& test "$rtems_cv_CFLAGS_set" != set],
>> -[CFLAGS="$CFLAGS -Wall -Wimplicit-function-declaration
>> -Wstrict-prototypes -Wnested-externs"])
>> +[CFLAGS="$CFLAGS -Wall -Wmissing-prototypes
>> -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs"])
> Are these flags ok with the NIOS compiler ?
Yes, -Wmissing-prototypes is sufficiently old to be supported by ancient
GCCs, such as the nios2 toolchain.
But why are you asking? Doesn't it work for you?
Ralf
