Stack allocator change was Re: change log for rtems (2011-12-14)
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Dec 14 14:33:39 UTC 2011
On 12/14/2011 08:19 AM, Sebastian Huber wrote:
> On 12/14/2011 03:06 PM, Joel Sherrill wrote:
>> This change necessitates changes to doc/user/conf.t
>> and adds a user visible configuration change that needs
>> to be noted in the evolving 4.11 release notes:
>> http://www.rtems.org/wiki/index.php/4.11_Release_Notes
> I write the documentation currently. The conf.t is quite out of sync.
If you have a list of things to fix, please file a PR with them. It is
challenging to keep up. I have updated it a lot.
> Can I build the doc outside the source tree?
Yes. It worked for me when I committed the patches that moved
us to texi2html
Joel Sherrill, Ph.D. Director of Research& Development
