ioctl_return and ioctl handler type
Tue Apr 3 08:34:21 UTC 2012
Hello,
why is the ioctl_return type uint32_t and not int?
  * @brief Parameter block for ioctl.
typedef struct {
   rtems_libio_t          *iop;
   uint32_t                command;
   void                   *buffer;
   uint32_t                ioctl_return;
} rtems_libio_ioctl_args_t;
It is used here:
static int
rtems_rfs_rtems_device_ioctl (rtems_libio_t* iop,
                               uint32_t       command,
                               void*          buffer)
   status = rtems_io_control (major, minor, (void *) &args);
   if (status)
     return rtems_deviceio_errno (status);
   return args.ioctl_return;
int device_ioctl(
   rtems_libio_t *iop,
   uint32_t       command,
   void          *buffer
   status = rtems_io_control(
     the_jnode->info.device.major,
     the_jnode->info.device.minor,
     (void *) &args
   if ( status )
     return rtems_deviceio_errno(status);
int devFS_ioctl(
   rtems_libio_t *iop,
   uint32_t       command,
   void          *buffer
     np->major,
     np->minor,
     (void *) &args
   if ( status )
We always have an uint32_t to int conversion, since the function type is
typedef int (*rtems_filesystem_ioctl_t)(
   rtems_libio_t *iop,
   uint32_t       request,
   void          *buffer
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
