[PATCH 27.0 1/3] LEON: implemented shared-irq using libbsp/shared layer
Daniel Hellstrom
daniel at gaisler.com
Thu Apr 5 15:23:15 UTC 2012
The implementation use IRQ number instead of vector number since
some IRQs does not have a unique vector, for example the extended
interrupts all enter the same trap vector entry.
Added support for the LEON3 extended interrupt controller when using
the shared IRQ layer.
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
c/src/lib/libbsp/sparc/Makefile.am | 3 +
c/src/lib/libbsp/sparc/leon2/Makefile.am | 14 +++-
c/src/lib/libbsp/sparc/leon2/include/bsp.h | 74 +++++++++++++
c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h | 20 ++++
c/src/lib/libbsp/sparc/leon2/include/leon.h | 5 +
c/src/lib/libbsp/sparc/leon2/preinstall.am | 12 ++
.../lib/libbsp/sparc/leon2/startup/bsppredriver.c | 25 +++++
c/src/lib/libbsp/sparc/leon3/Makefile.am | 15 +++-
c/src/lib/libbsp/sparc/leon3/amba/amba.c | 6 +
c/src/lib/libbsp/sparc/leon3/include/bsp.h | 74 +++++++++++++
c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h | 36 +++++++
c/src/lib/libbsp/sparc/leon3/include/leon.h | 17 +++
c/src/lib/libbsp/sparc/leon3/preinstall.am | 12 ++
.../lib/libbsp/sparc/leon3/startup/bsppredriver.c | 27 +++++
c/src/lib/libbsp/sparc/leon3/startup/eirq.c | 27 +++++
c/src/lib/libbsp/sparc/shared/include/ambapp.h | 2 +
c/src/lib/libbsp/sparc/shared/irq/irq-shared.c | 110 ++++++++++++++++++++
17 files changed, 477 insertions(+), 2 deletions(-)
create mode 100644 c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h
create mode 100644 c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
create mode 100644 c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h
create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/eirq.c
create mode 100644 c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
index b1b6a22..4f445ba 100644
--- a/c/src/lib/libbsp/sparc/Makefile.am
+++ b/c/src/lib/libbsp/sparc/Makefile.am
@@ -12,6 +12,9 @@ EXTRA_DIST =
EXTRA_DIST += shared/gnatcommon.c
EXTRA_DIST += shared/start.S
+# Interrupt
+EXTRA_DIST += shared/irq/irq-shared.c
# AMBA Plug&Play bus
EXTRA_DIST += shared/include/ambapp.h
EXTRA_DIST += shared/amba/ambapp.c
diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
index 6e2697f..c0102db 100644
--- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
@@ -51,7 +51,7 @@ libbsp_a_SOURCES =
# startup
libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
- ../../shared/bsppost.c ../../shared/bsppredriverhook.c \
+ ../../shared/bsppost.c startup/bsppredriver.c \
startup/bspstart.c ../../sparc/shared/bsppretaskinghook.c \
../../sparc/shared/bspgetworkarea.c ../../shared/bootcard.c \
../../shared/sbrk.c startup/setvec.c startup/spurious.c startup/bspidle.c \
@@ -66,6 +66,18 @@ libbsp_a_SOURCES += console/console.c console/debugputs.c
# clock
libbsp_a_SOURCES += clock/ckinit.c
libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
+# IRQ
+include_bsp_HEADERS = \
+ ../../shared/include/irq-generic.h \
+ ../../shared/include/irq-info.h \
+ include/bsp/irq.h
+libbsp_a_SOURCES += \
+ ../../sparc/shared/irq/irq-shared.c \
+ ../../shared/src/irq-generic.c \
+ ../../shared/src/irq-legacy.c \
+ ../../shared/src/irq-info.c \
+ ../../shared/src/irq-shell.c \
+ ../../shared/src/irq-server.c
# AMBA PnP Scanning
libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp.c
# PCI
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
index a2f3360..b087e06 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
@@ -30,6 +30,7 @@ extern "C" {
#include <leon.h>
#include <rtems/clockdrv.h>
#include <rtems/console.h>
+#include <rtems/irq-extension.h>
/* SPARC CPU variant: LEON2 */
#define LEON2 1
@@ -109,6 +110,79 @@ void bsp_spurious_initialize( void );
void *bsp_early_malloc(int size);
+/* Interrupt Service Routine (ISR) pointer */
+typedef void (*bsp_shared_isr)(void *arg);
+/* Initializes the Shared System Interrupt service */
+extern int BSP_shared_interrupt_init(void);
+/* Registers a shared IRQ handler, and enable it at IRQ controller. Multiple
+ * interrupt handlers may use the same IRQ number, all ISRs will be called
+ * when an interrupt on that line is fired.
+ * Arguments
+ * irq System IRQ number
+ * info Optional Name of IRQ source
+ * isr Function pointer to the ISR
+ * arg Second argument to function isr
+static __inline__ int BSP_shared_interrupt_register
+ int irq,
+ const char *info,
+ bsp_shared_isr isr,
+ void *arg
+ return rtems_interrupt_handler_install(irq, info,
+ RTEMS_INTERRUPT_SHARED, isr, arg);
+/* Unregister previously registered shared IRQ handler.
+ * Arguments
+static __inline__ int BSP_shared_interrupt_unregister
+ int irq,
+ void *arg
+ return rtems_interrupt_handler_remove(irq, isr, arg);
+/* Clear interrupt pending on IRQ controller, this is typically done on a
+ * level triggered interrupt source such as PCI to avoid taking double IRQs.
+ * In such a case the interrupt source must be cleared first on LEON, before
+ * acknowledging the IRQ with this function.
+ * Arguments
+extern void BSP_shared_interrupt_clear(int irq);
+/* Enable Interrupt. This function will unmask the IRQ at the interrupt
+ * controller. This is normally done by _register(). Note that this will
+ * affect all ISRs on this IRQ.
+ * Arguments
+extern void BSP_shared_interrupt_unmask(int irq);
+/* Disable Interrupt. This function will mask one IRQ at the interrupt
+ * controller. This is normally done by _unregister(). Note that this will
+ * Arguments
+extern void BSP_shared_interrupt_mask(int irq);
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h b/c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h
new file mode 100644
index 0000000..709b563
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h
@@ -0,0 +1,20 @@
+/* LEON2 generic shared IRQ setup
+ * Based on libbsp/shared/include/irq.h.
+ * http://www.rtems.com/license/LICENSE.
+#ifndef LIBBSP_LEON2_IRQ_CONFIG_H
+#define LIBBSP_LEON2_IRQ_CONFIG_H
+#define BSP_INTERRUPT_VECTOR_MAX_STD 15 /* Standard IRQ controller */
+#define BSP_INTERRUPT_VECTOR_MIN 0
+#define BSP_INTERRUPT_VECTOR_MAX BSP_INTERRUPT_VECTOR_MAX_STD
+/* No extra check is needed */
+#undef BSP_INTERRUPT_CUSTOM_VALID_VECTOR
+#endif /* LIBBSP_LEON2_IRQ_CONFIG_H */
diff --git a/c/src/lib/libbsp/sparc/leon2/include/leon.h b/c/src/lib/libbsp/sparc/leon2/include/leon.h
index c183c90..8cfc761 100644
--- a/c/src/lib/libbsp/sparc/leon2/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon2/include/leon.h
@@ -271,6 +271,11 @@ typedef struct {
extern LEON_Register_Map LEON_REG;
+static __inline__ int leon_irq_fixup(int irq)
+ return irq;
* Macros to manipulate the Interrupt Clear, Interrupt Force, Interrupt Mask,
* and the Interrupt Pending Registers.
diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
index 4b7d4da..00ed05e 100644
--- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
@@ -145,6 +145,18 @@ $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(d
$(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
+$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
+$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
+$(PROJECT_INCLUDE)/bsp/irq.h: include/bsp/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
$(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLUDE)/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/i2cmst.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
diff --git a/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
index 0000000..f64cca6
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
@@ -0,0 +1,25 @@
+/* Installs the BSP pre-driver hook
+ * COPYRIGHT (c) 2011
+ * Aeroflex Gaisler
+ * $Id$
+ * bsp_predriver_hook
+ * BSP predriver hook. Called just before drivers are initialized.
+ * Is used to initialize shared interrupt handling.
+void bsp_predriver_hook( void )
+ /* Initialize shared interrupt handling, must be done after IRQ
+ * controller has been found and initialized.
+ BSP_shared_interrupt_init();
diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
index dc24051..013be52 100644
--- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
+++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
@@ -35,7 +35,7 @@ libbsp_a_SOURCES =
# startup
../../shared/bsppost.c ../../shared/bootcard.c startup/bspstart.c \
- ../../sparc/shared/bsppretaskinghook.c ../../shared/bsppredriverhook.c \
+ ../../sparc/shared/bsppretaskinghook.c startup/bsppredriver.c \
../../sparc/shared/bspgetworkarea.c ../../shared/sbrk.c startup/setvec.c \
startup/spurious.c startup/bspidle.S startup/bspdelay.c \
../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
@@ -55,6 +55,19 @@ libbsp_a_SOURCES += console/debugputs.c
# clock
+# IRQ
+ include/bsp/irq.h
+ startup/eirq.c \
# PCI
include_HEADERS += ../../sparc/shared/include/pci.h
libbsp_a_SOURCES += pci/pci.c ../../sparc/shared/pci/pcifinddevice.c
diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
index b0a43f9..03af226 100644
--- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
+++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
@@ -18,6 +18,9 @@
/* Structure containing address to devices found on the Amba Plug&Play bus */
amba_confarea_type amba_conf;
+/* GRLIB extended IRQ controller register */
+extern void leon3_ext_irq_init(void);
/* Pointers to Interrupt Controller configuration registers */
volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
@@ -48,6 +51,9 @@ void amba_initialize(void)
LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *) dev.start;
+ /* Init Extended IRQ controller if available */
+ leon3_ext_irq_init();
/* find GP Timer */
i = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&dev);
if ( i > 0 ){
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
index 04279d9..fc42773 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
#include <leon.h>
/* SPARC CPU variant: LEON3 */
#define LEON3 1
@@ -119,6 +120,79 @@ void bsp_spurious_initialize( void );
+ * Arguments
+ int irq,
+ const char *info,
+ void *arg
+ * Arguments
+ int irq,
+ void *arg
+ * Arguments
+ * Arguments
+ * Arguments
#ifdef __cplusplus
#endif
diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h b/c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h
index 0000000..71c0df3
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h
@@ -0,0 +1,36 @@
+/* LEON3 generic shared IRQ setup
+#ifndef LIBBSP_LEON3_IRQ_CONFIG_H
+#define LIBBSP_LEON3_IRQ_CONFIG_H
+#define BSP_INTERRUPT_VECTOR_MAX_EXT 31 /* Extended IRQ controller */
+#define BSP_INTERRUPT_VECTOR_MAX BSP_INTERRUPT_VECTOR_MAX_EXT
+/* The check is different depending on IRQ controller, runtime detected */
+#define BSP_INTERRUPT_CUSTOM_VALID_VECTOR
+extern int LEON3_IrqCtrl_EIrq;
+ * @brief Returns true if the interrupt vector with number @a vector is valid.
+static inline bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
+ return (rtems_vector_number) BSP_INTERRUPT_VECTOR_MIN <= vector
+ && ((vector <= (rtems_vector_number) BSP_INTERRUPT_VECTOR_MAX_STD &&
+ LEON3_IrqCtrl_EIrq == 0) ||
+ (vector <= (rtems_vector_number) BSP_INTERRUPT_VECTOR_MAX_EXT &&
+ LEON3_IrqCtrl_EIrq != 0));
+#endif /* LIBBSP_LEON3_IRQ_CONFIG_H */
diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
index fd208b0..c7a302b 100644
--- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
+++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
@@ -152,6 +152,23 @@ extern volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
/* LEON3 CPU Index of boot CPU */
extern int LEON3_Cpu_Index;
+/* The external IRQ number, -1 if not external interrupts */
+ int eirq;
+ if (LEON3_IrqCtrl_EIrq != 0 && irq == LEON3_IrqCtrl_EIrq) {
+ /* Get interrupt number from IRQ controller */
+ eirq = LEON3_IrqCtrl_Regs->intid[LEON3_Cpu_Index] & 0x1f;
+ if (eirq & 0x10)
+ irq = eirq;
+ return irq;
/* Macros used for manipulating bits in LEON3 GP Timer Control Register */
#define LEON3_GPTIMER_EN 1
diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
index b948529..8c27b81 100644
--- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
+++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
@@ -85,6 +85,18 @@ $(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLU
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/ambapp.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp.h
$(PROJECT_INCLUDE)/pci.h: ../../sparc/shared/include/pci.h $(PROJECT_INCLUDE)/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/pci.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/pci.h
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
index 0000000..ff633fe
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
@@ -0,0 +1,27 @@
+ * $Id$
+#include <bsp.h>
diff --git a/c/src/lib/libbsp/sparc/leon3/startup/eirq.c b/c/src/lib/libbsp/sparc/leon3/startup/eirq.c
index 0000000..68089a3
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/leon3/startup/eirq.c
@@ -0,0 +1,27 @@
+ * GRLIB/LEON3 extended interrupt controller
+#include <bsp.h>
+extern int LEON3_Cpu_Index;
+/* GRLIB extended IRQ controller IRQ number */
+int LEON3_IrqCtrl_EIrq = -1;
+/* Initialize Exteneded Interrupt controller */
+void leon3_ext_irq_init(void)
+ if ( (LEON3_IrqCtrl_Regs->mpstat >> 16) & 0xf ) {
+ /* Extended IRQ controller available */
+ LEON3_IrqCtrl_EIrq = (LEON3_IrqCtrl_Regs->mpstat >> 16) & 0xf;
diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp.h b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
index e2b557d..cc8e120 100644
--- a/c/src/lib/libbsp/sparc/shared/include/ambapp.h
+++ b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
@@ -272,6 +272,8 @@ typedef struct {
volatile unsigned int notused23;
volatile unsigned int mask[16];
volatile unsigned int force[16];
+ /* Extended IRQ registers */
+ volatile unsigned int intid[16];
} LEON3_IrqCtrl_Regs_Map;
diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
index 0000000..99480e4
--- /dev/null
+++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
@@ -0,0 +1,110 @@
+#include <rtems.h>
+#include <bsp.h>
+#include <bsp/irq-generic.h>
+#include <leon.h>
+static inline void leon_dispatch_irq(int irq)
+ bsp_interrupt_handler_entry *e =
+ &bsp_interrupt_handler_table[bsp_interrupt_handler_index(irq)];
+ while (e != NULL) {
+ (*e->handler)(e->arg);
+ e = e->next;
+/* Called directly from IRQ trap handler TRAP[0x10..0x1F] = IRQ[0..15] */
+void LEON_ISR_handler(rtems_vector_number vector)
+ int irq = LEON_TRAP_SOURCE(vector);
+ /* Let BSP fixup and/or handle incomming IRQ */
+ irq = leon_irq_fixup(irq);
+ leon_dispatch_irq(irq);
+/* Initialize interrupts */
+int BSP_shared_interrupt_init(void)
+ rtems_vector_number vector;
+ rtems_isr_entry previous_isr;
+ int sc, i;
+ for (i=0; i <= BSP_INTERRUPT_VECTOR_MAX_STD; i++) {
+ vector = LEON_TRAP_TYPE(i);
+ rtems_interrupt_catch(LEON_ISR_handler, vector, &previous_isr);
+ /* Initalize interrupt support */
+ sc = bsp_interrupt_initialize();
+ if (sc != RTEMS_SUCCESSFUL)
+ return -1;
+ return 0;
+/* Callback from bsp_interrupt_initialize() */
+rtems_status_code bsp_interrupt_facility_initialize(void)
+ return RTEMS_SUCCESSFUL;
+/* Spurious IRQ handler */
+void bsp_interrupt_handler_default(rtems_vector_number vector)
+ printk("Spurious IRQ %d\n", (int)vector);
+rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
+ rtems_interrupt_level level;
+ rtems_interrupt_disable(level);
+ LEON_Unmask_interrupt((int)vector);
+ rtems_interrupt_enable(level);
+rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
+ LEON_Mask_interrupt((int)vector);
+void BSP_shared_interrupt_mask(int irq)
+ LEON_Mask_interrupt(irq);
+void BSP_shared_interrupt_unmask(int irq)
+ LEON_Unmask_interrupt(irq);
+void BSP_shared_interrupt_clear(int irq)
+ /* We don't have to interrupt lock here, because the register is only
+ * written and self clearing
+ LEON_Clear_interrupt(irq);
1.7.0.4
