[PATCH 29] LEON3: console use register pointers instead of UART indexes
Daniel Hellstrom daniel at gaisler.com
Thu Apr 5 15:23:19 UTC 2012
Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
 c/src/lib/libbsp/sparc/leon3/console/console.c   |   16 ++++----
 c/src/lib/libbsp/sparc/leon3/console/debugputs.c |   50 +++++++++++-----------
 2 files changed, 33 insertions(+), 33 deletions(-)
diff --git a/c/src/lib/libbsp/sparc/leon3/console/console.c b/c/src/lib/libbsp/sparc/leon3/console/console.c
index a07fb15..320aa37 100644
--- a/c/src/lib/libbsp/sparc/leon3/console/console.c
+++ b/c/src/lib/libbsp/sparc/leon3/console/console.c
@@ -40,13 +40,13 @@ int syscon_uart_index __attribute__((weak)) = 0;
- *  console_outbyte_polled
+ *  apbuart_outbyte_polled
  *  This routine transmits a character using polling.
-void console_outbyte_polled(
-  int  port,
+extern void apbuart_outbyte_polled(
+  ambapp_apb_uart *regs,
   char ch
@@ -58,7 +58,7 @@ void console_outbyte_polled(
  *  This routine polls for a character.
-int apbuart_inbyte_nonblocking(int port);
+extern int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs);
 /* body is in debugputs.c */
@@ -78,13 +78,13 @@ ssize_t console_write_support (int minor, const char *buf, size_t len)
     port = minor - 1;
   while (nwrite < len) {
-    console_outbyte_polled(port, *buf++);
+    apbuart_outbyte_polled((ambapp_apb_uart*)LEON3_Console_Uart[port], *buf++);
     nwrite++;
   return nwrite;
-int console_inbyte_nonblocking(int minor)
+int console_pollRead(int minor)
   int port;
@@ -93,7 +93,7 @@ int console_inbyte_nonblocking(int minor)
   else
     port = minor - 1;
-  return apbuart_inbyte_nonblocking(port);
+  return apbuart_inbyte_nonblocking((ambapp_apb_uart*)LEON3_Console_Uart[port]);
@@ -168,7 +168,7 @@ rtems_device_driver console_open(
   static const rtems_termios_callbacks pollCallbacks = {
     NULL,                        /* firstOpen */
     NULL,                        /* lastClose */
-    console_inbyte_nonblocking,  /* pollRead */
+    console_pollRead,            /* pollRead */
     console_write_support,       /* write */
     NULL,                        /* setAttributes */
     NULL,                        /* stopRemoteTx */
diff --git a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
index cf3f280..43c6d7d 100644
--- a/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
+++ b/c/src/lib/libbsp/sparc/leon3/console/debugputs.c
@@ -21,6 +21,7 @@
 #include <rtems/libio.h>
 #include <assert.h>
+#include <stdio.h>
  * Number of uarts on AMBA bus
@@ -37,6 +38,7 @@ static int isinit = 0;
 int debug_uart_index __attribute__((weak)) = 0;
+ambapp_apb_uart *dbg_uart = NULL;
  *  Scan for UARTS in configuration
@@ -74,9 +76,9 @@ int scan_uarts(void)
     /* initialize debug uart if present for printk */
     if (debug_uart_index < uarts) {
-      LEON3_Console_Uart[debug_uart_index]->ctrl |= LEON_REG_UART_CTRL_RE |
-                                                    LEON_REG_UART_CTRL_TE;
-      LEON3_Console_Uart[debug_uart_index]->status = 0;
+      dbg_uart = (ambapp_apb_uart *)LEON3_Console_Uart[debug_uart_index];
+      dbg_uart->ctrl |= LEON_REG_UART_CTRL_RE | LEON_REG_UART_CTRL_TE;
+      dbg_uart->status = 0;
     isinit = 1;
@@ -85,48 +87,43 @@ int scan_uarts(void)
-  int           port,
+void apbuart_outbyte_polled(
   unsigned char ch
-  if ((port >= 0) && (port < uarts)) {
-    return;
-  while ( (LEON3_Console_Uart[port]->status & LEON_REG_UART_STATUS_THE) == 0 );
-  LEON3_Console_Uart[port]->data = (unsigned int) ch;
+  while ( (regs->status & LEON_REG_UART_STATUS_THE) == 0 );
+  regs->data = (unsigned int) ch;
- *  console_inbyte_nonblocking
+ *  apbuart_inbyte_nonblocking
+int apbuart_inbyte_nonblocking(ambapp_apb_uart *regs)
-    assert( 0 );
-    return -1;
   /* Clear errors */
-  if (LEON3_Console_Uart[port]->status & LEON_REG_UART_STATUS_ERR)
-    LEON3_Console_Uart[port]->status = ~LEON_REG_UART_STATUS_ERR;
+  if (regs->status & LEON_REG_UART_STATUS_ERR)
+    regs->status = ~LEON_REG_UART_STATUS_ERR;
-  if ((LEON3_Console_Uart[port]->status & LEON_REG_UART_STATUS_DR) == 0)
-    return -1;
+  if ((regs->status & LEON_REG_UART_STATUS_DR) == 0)
+    return EOF;
   else
-    return (int) LEON3_Console_Uart[port]->data;
+    return (int) regs->data;
 /* putchar/getchar for printk */
 static void bsp_out_char(char c)
-  console_outbyte_polled(debug_uart_index, c);
+  if (dbg_uart == NULL)
+    return;
+  apbuart_outbyte_polled(dbg_uart, c);
@@ -141,7 +138,10 @@ static int bsp_in_char(void)
   int tmp;
-  while ((tmp = apbuart_inbyte_nonblocking(debug_uart_index)) < 0)
+    return EOF;
+  while ((tmp = apbuart_inbyte_nonblocking(dbg_uart)) < 0)
   return tmp;
1.7.0.4
