[PATCH 27.0 1/3] LEON: implemented shared-irq using libbsp/shared layer
Thu Apr 5 15:38:02 UTC 2012
I am happy to see this BUT... it leaves ONE
other BSPs in the same architecture without
this feature.
Could you please make the set complete and add
this to the ERC32 as well? Looking at leon2 changes,
it doesn't look like a lot to do.
I hate to ask this but inconsistency sucks. I imposed
this requirement on us for the MIPS and we got
the privilege of fixing 6 BSPs plus the one we really
needed it on.
Take care of this and I think 27 is a no brainer to
merge given no warnings. :)
--joel
On 04/05/2012 10:23 AM, Daniel Hellstrom wrote:
> The implementation use IRQ number instead of vector number since
> some IRQs does not have a unique vector, for example the extended
> interrupts all enter the same trap vector entry.
> Added support for the LEON3 extended interrupt controller when using
> the shared IRQ layer.
> Signed-off-by: Daniel Hellstrom<daniel at gaisler.com>
>   c/src/lib/libbsp/sparc/Makefile.am                 |    3 +
>   c/src/lib/libbsp/sparc/leon2/Makefile.am           |   14 +++-
>   c/src/lib/libbsp/sparc/leon2/include/bsp.h         |   74 +++++++++++++
>   c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h     |   20 ++++
>   c/src/lib/libbsp/sparc/leon2/include/leon.h        |    5 +
>   c/src/lib/libbsp/sparc/leon2/preinstall.am         |   12 ++
>   .../lib/libbsp/sparc/leon2/startup/bsppredriver.c  |   25 +++++
>   c/src/lib/libbsp/sparc/leon3/Makefile.am           |   15 +++-
>   c/src/lib/libbsp/sparc/leon3/amba/amba.c           |    6 +
>   c/src/lib/libbsp/sparc/leon3/include/bsp.h         |   74 +++++++++++++
>   c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h     |   36 +++++++
>   c/src/lib/libbsp/sparc/leon3/include/leon.h        |   17 +++
>   c/src/lib/libbsp/sparc/leon3/preinstall.am         |   12 ++
>   .../lib/libbsp/sparc/leon3/startup/bsppredriver.c  |   27 +++++
>   c/src/lib/libbsp/sparc/leon3/startup/eirq.c        |   27 +++++
>   c/src/lib/libbsp/sparc/shared/include/ambapp.h     |    2 +
>   c/src/lib/libbsp/sparc/shared/irq/irq-shared.c     |  110 ++++++++++++++++++++
>   17 files changed, 477 insertions(+), 2 deletions(-)
>   create mode 100644 c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h
>   create mode 100644 c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
>   create mode 100644 c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h
>   create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
>   create mode 100644 c/src/lib/libbsp/sparc/leon3/startup/eirq.c
>   create mode 100644 c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> diff --git a/c/src/lib/libbsp/sparc/Makefile.am b/c/src/lib/libbsp/sparc/Makefile.am
> index b1b6a22..4f445ba 100644
> --- a/c/src/lib/libbsp/sparc/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/Makefile.am
> @@ -12,6 +12,9 @@ EXTRA_DIST =
>   EXTRA_DIST += shared/gnatcommon.c
>   EXTRA_DIST += shared/start.S
> +# Interrupt
> +EXTRA_DIST += shared/irq/irq-shared.c
>   # AMBA Plug&Play bus
>   EXTRA_DIST += shared/include/ambapp.h
>   EXTRA_DIST += shared/amba/ambapp.c
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index 6e2697f..c0102db 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -51,7 +51,7 @@ libbsp_a_SOURCES =
>   # startup
>   libbsp_a_SOURCES += ../../shared/bspclean.c ../../shared/bsplibc.c \
> -    ../../shared/bsppost.c ../../shared/bsppredriverhook.c \
> +    ../../shared/bsppost.c startup/bsppredriver.c \
>       startup/bspstart.c ../../sparc/shared/bsppretaskinghook.c \
>       ../../sparc/shared/bspgetworkarea.c ../../shared/bootcard.c \
>       ../../shared/sbrk.c startup/setvec.c startup/spurious.c startup/bspidle.c \
> @@ -66,6 +66,18 @@ libbsp_a_SOURCES += console/console.c console/debugputs.c
>   # clock
>   libbsp_a_SOURCES += clock/ckinit.c
>   libbsp_a_SOURCES += ../../shared/clockdrv_shell.h
> +# IRQ
> +include_bsp_HEADERS = \
> +    ../../shared/include/irq-generic.h \
> +    ../../shared/include/irq-info.h \
> +    include/bsp/irq.h
> +libbsp_a_SOURCES += \
> +    ../../sparc/shared/irq/irq-shared.c \
> +    ../../shared/src/irq-generic.c \
> +    ../../shared/src/irq-legacy.c \
> +    ../../shared/src/irq-info.c \
> +    ../../shared/src/irq-shell.c \
> +    ../../shared/src/irq-server.c
>   # AMBA PnP Scanning
>   libbsp_a_SOURCES += ../../sparc/shared/amba/ambapp.c
>   # PCI
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp.h b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> index a2f3360..b087e06 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp.h
> @@ -30,6 +30,7 @@ extern "C" {
>   #include<leon.h>
>   #include<rtems/clockdrv.h>
>   #include<rtems/console.h>
> +#include<rtems/irq-extension.h>
>   /* SPARC CPU variant: LEON2 */
>   #define LEON2 1
> @@ -109,6 +110,79 @@ void bsp_spurious_initialize( void );
>   void *bsp_early_malloc(int size);
> +/* Interrupt Service Routine (ISR) pointer */
> +typedef void (*bsp_shared_isr)(void *arg);
> +/* Initializes the Shared System Interrupt service */
> +extern int BSP_shared_interrupt_init(void);
> +/* Registers a shared IRQ handler, and enable it at IRQ controller. Multiple
> + * interrupt handlers may use the same IRQ number, all ISRs will be called
> + * when an interrupt on that line is fired.
> + * Arguments
> + *  irq       System IRQ number
> + *  info      Optional Name of IRQ source
> + *  isr       Function pointer to the ISR
> + *  arg       Second argument to function isr
> +static __inline__ int BSP_shared_interrupt_register
> +       int irq,
> +       const char *info,
> +       bsp_shared_isr isr,
> +       void *arg
> +       return rtems_interrupt_handler_install(irq, info,
> +                                       RTEMS_INTERRUPT_SHARED, isr, arg);
> +/* Unregister previously registered shared IRQ handler.
> + * Arguments
> +static __inline__ int BSP_shared_interrupt_unregister
> +       int irq,
> +       void *arg
> +       return rtems_interrupt_handler_remove(irq, isr, arg);
> +/* Clear interrupt pending on IRQ controller, this is typically done on a
> + * level triggered interrupt source such as PCI to avoid taking double IRQs.
> + * In such a case the interrupt source must be cleared first on LEON, before
> + * acknowledging the IRQ with this function.
> + * Arguments
> +extern void BSP_shared_interrupt_clear(int irq);
> +/* Enable Interrupt. This function will unmask the IRQ at the interrupt
> + * controller. This is normally done by _register(). Note that this will
> + * affect all ISRs on this IRQ.
> + * Arguments
> +extern void BSP_shared_interrupt_unmask(int irq);
> +/* Disable Interrupt. This function will mask one IRQ at the interrupt
> + * controller. This is normally done by _unregister().  Note that this will
> + * Arguments
> +extern void BSP_shared_interrupt_mask(int irq);
>   #ifdef __cplusplus
>   #endif
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h b/c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h
> new file mode 100644
> index 0000000..709b563
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/leon2/include/bsp/irq.h
> @@ -0,0 +1,20 @@
> +/* LEON2 generic shared IRQ setup
> + * Based on libbsp/shared/include/irq.h.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#ifndef LIBBSP_LEON2_IRQ_CONFIG_H
> +#define LIBBSP_LEON2_IRQ_CONFIG_H
> +#define BSP_INTERRUPT_VECTOR_MAX_STD 15 /* Standard IRQ controller */
> +#define BSP_INTERRUPT_VECTOR_MIN 0
> +#define BSP_INTERRUPT_VECTOR_MAX BSP_INTERRUPT_VECTOR_MAX_STD
> +/* No extra check is needed */
> +#undef BSP_INTERRUPT_CUSTOM_VALID_VECTOR
> +#endif /* LIBBSP_LEON2_IRQ_CONFIG_H */
> diff --git a/c/src/lib/libbsp/sparc/leon2/include/leon.h b/c/src/lib/libbsp/sparc/leon2/include/leon.h
> index c183c90..8cfc761 100644
> --- a/c/src/lib/libbsp/sparc/leon2/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon2/include/leon.h
> @@ -271,6 +271,11 @@ typedef struct {
>   extern LEON_Register_Map LEON_REG;
> +static __inline__ int leon_irq_fixup(int irq)
> +       return irq;
>    *  Macros to manipulate the Interrupt Clear, Interrupt Force, Interrupt Mask,
>    *  and the Interrupt Pending Registers.
> diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> index 4b7d4da..00ed05e 100644
> --- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> @@ -145,6 +145,18 @@ $(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base $(PROJECT_LIB)/$(d
>          $(INSTALL_DATA) $<  $(PROJECT_LIB)/linkcmds.base
>   PREINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
> +$(PROJECT_INCLUDE)/bsp/irq-generic.h: ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/bsp/irq-generic.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
> +$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/bsp/irq-info.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
> +$(PROJECT_INCLUDE)/bsp/irq.h: include/bsp/irq.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +       $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/bsp/irq.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>   $(PROJECT_INCLUDE)/i2cmst.h: ../../sparc/shared/include/i2cmst.h $(PROJECT_INCLUDE)/$(dirstamp)
>          $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/i2cmst.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/i2cmst.h
> diff --git a/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
> index 0000000..f64cca6
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/leon2/startup/bsppredriver.c
> @@ -0,0 +1,25 @@
> +/*  Installs the BSP pre-driver hook
> + *  COPYRIGHT (c) 2011
> + *  Aeroflex Gaisler
> + *  $Id$
> + *  bsp_predriver_hook
> + *  BSP predriver hook. Called just before drivers are initialized.
> + *  Is used to initialize shared interrupt handling.
> +void bsp_predriver_hook( void )
> +  /* Initialize shared interrupt handling, must be done after IRQ
> +   * controller has been found and initialized.
> +  BSP_shared_interrupt_init();
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index dc24051..013be52 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -35,7 +35,7 @@ libbsp_a_SOURCES =
>   # startup
>       ../../shared/bsppost.c ../../shared/bootcard.c startup/bspstart.c \
> -    ../../sparc/shared/bsppretaskinghook.c ../../shared/bsppredriverhook.c \
> +    ../../sparc/shared/bsppretaskinghook.c startup/bsppredriver.c \
>       ../../sparc/shared/bspgetworkarea.c ../../shared/sbrk.c startup/setvec.c \
>       startup/spurious.c startup/bspidle.S startup/bspdelay.c \
>       ../../shared/bspinit.c ../../sparc/shared/startup/early_malloc.c
> @@ -55,6 +55,19 @@ libbsp_a_SOURCES += console/debugputs.c
>   # clock
> +# IRQ
> +    include/bsp/irq.h
> +    startup/eirq.c \
>   # PCI
>   include_HEADERS += ../../sparc/shared/include/pci.h
>   libbsp_a_SOURCES += pci/pci.c ../../sparc/shared/pci/pcifinddevice.c
> diff --git a/c/src/lib/libbsp/sparc/leon3/amba/amba.c b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> index b0a43f9..03af226 100644
> --- a/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> +++ b/c/src/lib/libbsp/sparc/leon3/amba/amba.c
> @@ -18,6 +18,9 @@
>   /* Structure containing address to devices found on the Amba Plug&Play bus */
>   amba_confarea_type amba_conf;
> +/* GRLIB extended IRQ controller register */
> +extern void leon3_ext_irq_init(void);
>   /* Pointers to Interrupt Controller configuration registers */
>   volatile LEON3_IrqCtrl_Regs_Map *LEON3_IrqCtrl_Regs;
> @@ -48,6 +51,9 @@ void amba_initialize(void)
>       LEON3_IrqCtrl_Regs = (volatile LEON3_IrqCtrl_Regs_Map *) dev.start;
> +  /* Init Extended IRQ controller if available */
> +  leon3_ext_irq_init();
>     /* find GP Timer */
>     i = amba_find_apbslv(&amba_conf,VENDOR_GAISLER,GAISLER_GPTIMER,&dev);
>     if ( i>  0 ){
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp.h b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> index 04279d9..fc42773 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/bsp.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp.h
>   #include<leon.h>
>   /* SPARC CPU variant: LEON3 */
>   #define LEON3 1
> @@ -119,6 +120,79 @@ void bsp_spurious_initialize( void );
> + * Arguments
> +       int irq,
> +       const char *info,
> +       void *arg
> + * Arguments
> +       int irq,
> +       void *arg
> + * Arguments
> + * Arguments
> + * Arguments
>   #ifdef __cplusplus
>   #endif
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h b/c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h
> index 0000000..71c0df3
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/leon3/include/bsp/irq.h
> @@ -0,0 +1,36 @@
> +/* LEON3 generic shared IRQ setup
> +#ifndef LIBBSP_LEON3_IRQ_CONFIG_H
> +#define LIBBSP_LEON3_IRQ_CONFIG_H
> +#define BSP_INTERRUPT_VECTOR_MAX_EXT 31 /* Extended IRQ controller */
> +#define BSP_INTERRUPT_VECTOR_MAX BSP_INTERRUPT_VECTOR_MAX_EXT
> +/* The check is different depending on IRQ controller, runtime detected */
> +#define BSP_INTERRUPT_CUSTOM_VALID_VECTOR
> +extern int LEON3_IrqCtrl_EIrq;
> + * @brief Returns true if the interrupt vector with number @a vector is valid.
> +static inline bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
> +  return (rtems_vector_number) BSP_INTERRUPT_VECTOR_MIN<= vector
> +&&  ((vector<= (rtems_vector_number) BSP_INTERRUPT_VECTOR_MAX_STD&&
> +        LEON3_IrqCtrl_EIrq == 0) ||
> +       (vector<= (rtems_vector_number) BSP_INTERRUPT_VECTOR_MAX_EXT&&
> +        LEON3_IrqCtrl_EIrq != 0));
> +#endif /* LIBBSP_LEON3_IRQ_CONFIG_H */
> diff --git a/c/src/lib/libbsp/sparc/leon3/include/leon.h b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> index fd208b0..c7a302b 100644
> --- a/c/src/lib/libbsp/sparc/leon3/include/leon.h
> +++ b/c/src/lib/libbsp/sparc/leon3/include/leon.h
> @@ -152,6 +152,23 @@ extern volatile LEON3_UART_Regs_Map *LEON3_Console_Uart[LEON3_APBUARTS];
>   /* LEON3 CPU Index of boot CPU */
>   extern int LEON3_Cpu_Index;
> +/* The external IRQ number, -1 if not external interrupts */
> +       int eirq;
> +       if (LEON3_IrqCtrl_EIrq != 0&&  irq == LEON3_IrqCtrl_EIrq) {
> +               /* Get interrupt number from IRQ controller */
> +               eirq = LEON3_IrqCtrl_Regs->intid[LEON3_Cpu_Index]&  0x1f;
> +               if (eirq&  0x10)
> +                       irq = eirq;
> +       return irq;
>   /* Macros used for manipulating bits in LEON3 GP Timer Control Register */
>   #define LEON3_GPTIMER_EN 1
> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> index b948529..8c27b81 100644
> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> @@ -85,6 +85,18 @@ $(PROJECT_INCLUDE)/ambapp.h: ../../sparc/shared/include/ambapp.h $(PROJECT_INCLU
>          $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/ambapp.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/ambapp.h
>   $(PROJECT_INCLUDE)/pci.h: ../../sparc/shared/include/pci.h $(PROJECT_INCLUDE)/$(dirstamp)
>          $(INSTALL_DATA) $<  $(PROJECT_INCLUDE)/pci.h
>   PREINSTALL_FILES += $(PROJECT_INCLUDE)/pci.h
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c b/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
> index 0000000..ff633fe
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/bsppredriver.c
> @@ -0,0 +1,27 @@
> + *  $Id$
> +#include<bsp.h>
> diff --git a/c/src/lib/libbsp/sparc/leon3/startup/eirq.c b/c/src/lib/libbsp/sparc/leon3/startup/eirq.c
> index 0000000..68089a3
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/leon3/startup/eirq.c
> @@ -0,0 +1,27 @@
> + *  GRLIB/LEON3 extended interrupt controller
> +#include<bsp.h>
> +extern int LEON3_Cpu_Index;
> +/* GRLIB extended IRQ controller IRQ number */
> +int LEON3_IrqCtrl_EIrq = -1;
> +/* Initialize Exteneded Interrupt controller */
> +void leon3_ext_irq_init(void)
> +  if ( (LEON3_IrqCtrl_Regs->mpstat>>  16)&  0xf ) {
> +    /* Extended IRQ controller available */
> +    LEON3_IrqCtrl_EIrq = (LEON3_IrqCtrl_Regs->mpstat>>  16)&  0xf;
> diff --git a/c/src/lib/libbsp/sparc/shared/include/ambapp.h b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> index e2b557d..cc8e120 100644
> --- a/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> +++ b/c/src/lib/libbsp/sparc/shared/include/ambapp.h
> @@ -272,6 +272,8 @@ typedef struct {
>     volatile unsigned int notused23;
>     volatile unsigned int mask[16];
>     volatile unsigned int force[16];
> +  /* Extended IRQ registers */
> +  volatile unsigned int intid[16];
>   } LEON3_IrqCtrl_Regs_Map;
> diff --git a/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> index 0000000..99480e4
> --- /dev/null
> +++ b/c/src/lib/libbsp/sparc/shared/irq/irq-shared.c
> @@ -0,0 +1,110 @@
> +#include<rtems.h>
> +#include<bsp.h>
> +#include<bsp/irq-generic.h>
> +#include<leon.h>
> +static inline void leon_dispatch_irq(int irq)
> +       bsp_interrupt_handler_entry *e =
> +&bsp_interrupt_handler_table[bsp_interrupt_handler_index(irq)];
> +       while (e != NULL) {
> +               (*e->handler)(e->arg);
> +               e = e->next;
> +/* Called directly from IRQ trap handler TRAP[0x10..0x1F] = IRQ[0..15] */
> +void LEON_ISR_handler(rtems_vector_number vector)
> +       int irq = LEON_TRAP_SOURCE(vector);
> +       /* Let BSP fixup and/or handle incomming IRQ */
> +       irq = leon_irq_fixup(irq);
> +       leon_dispatch_irq(irq);
> +/* Initialize interrupts */
> +int BSP_shared_interrupt_init(void)
> +       rtems_vector_number vector;
> +       rtems_isr_entry previous_isr;
> +       int sc, i;
> +       for (i=0; i<= BSP_INTERRUPT_VECTOR_MAX_STD; i++) {
> +               vector = LEON_TRAP_TYPE(i);
> +               rtems_interrupt_catch(LEON_ISR_handler, vector,&previous_isr);
> +       /* Initalize interrupt support */
> +       sc = bsp_interrupt_initialize();
> +       if (sc != RTEMS_SUCCESSFUL)
> +               return -1;
> +       return 0;
> +/* Callback from bsp_interrupt_initialize() */
> +rtems_status_code bsp_interrupt_facility_initialize(void)
> +       return RTEMS_SUCCESSFUL;
> +/* Spurious IRQ handler */
> +void bsp_interrupt_handler_default(rtems_vector_number vector)
> +       printk("Spurious IRQ %d\n", (int)vector);
> +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
> +       rtems_interrupt_level level;
> +       rtems_interrupt_disable(level);
> +       LEON_Unmask_interrupt((int)vector);
> +       rtems_interrupt_enable(level);
> +rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
> +       LEON_Mask_interrupt((int)vector);
> +void BSP_shared_interrupt_mask(int irq)
> +       LEON_Mask_interrupt(irq);
> +void BSP_shared_interrupt_unmask(int irq)
> +       LEON_Unmask_interrupt(irq);
> +void BSP_shared_interrupt_clear(int irq)
> +       /* We don't have to interrupt lock here, because the register is only
> +        * written and self clearing
> +       LEON_Clear_interrupt(irq);
> 1.7.0.4
> rtems-devel mailing list
> rtems-devel at rtems.org
Joel Sherrill, Ph.D.             Director of Research&   Development
