Debug for x86
Fered a_Fered at yahoo.com
Fri Apr 6 03:41:17 UTC 2012
Hi Wendell;
Thank you for your answer.
It's a brief help. I need more explanation. Is it available manuals for
eclipse integration and usage of gdb and eclipse for RTEMS?
Regards.
Wendell Silva wrote:
> Hi Fered,
> If your target has a serial port, you could make use of gdb glue-code on
> the target.
> In the host side (eclipse) customize the debug properties to use
> i386-rtems<version>-gdb.exe.
> A detailed explanation on such a glue-code for gdb can be found:
>    - rtems/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO.
> Hope it helps.
> --Wendell.
> 2012/4/5 Fered <a_Fered at yahoo.com>
> > Hi;
> > How can I debug my RTEMS application for x86 target machine, on a linux
> > host
> > OS on a PC?
> > I mean, is there a solution same as developing and debugging a C
> > application
> > on a linux using an IDE such as eclipse?
> > Thanks.
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
