Debug for x86
Fri Apr 6 15:07:15 UTC 2012
http://www.rtems.com/wiki/index.php?title=Special%3ASearch&search=eclipse&go=Go
not much info on using gdb+eclipse specifically in RTEMS but I think
you can find that out other places once you have eclipse working.
On Thu, Apr 5, 2012 at 11:41 PM, Fered <a_Fered at yahoo.com> wrote:
> Hi Wendell;
> Thank you for your answer.
> It's a brief help. I need more explanation. Is it available manuals for
> eclipse integration and usage of gdb and eclipse for RTEMS?
> Regards.
> Wendell Silva wrote:
>> Hi Fered,
>> If your target has a serial port, you could make use of gdb glue-code on
>> the target.
>> In the host side (eclipse) customize the debug properties to use
>> i386-rtems<version>-gdb.exe.
>> A detailed explanation on such a glue-code for gdb can be found:
>>    - rtems/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO.
>> Hope it helps.
>> --Wendell.
>> 2012/4/5 Fered <a_Fered at yahoo.com>
>> > Hi;
>> > How can I debug my RTEMS application for x86 target machine, on a linux
>> > host
>> > OS on a PC?
>> > I mean, is there a solution same as developing and debugging a C
>> > application
>> > on a linux using an IDE such as eclipse?
>> > Thanks.
>> > _______________________________________________
>> > rtems-devel mailing list
>> > rtems-devel at rtems.org
>> > http://www.rtems.org/mailman/listinfo/rtems-devel
