Debug for x86
Sat Apr 7 15:07:55 UTC 2012
gdb is available for most (all?) of rtems targets.
On Sat, Apr 7, 2012 at 6:24 AM, Fered <a_Fered at yahoo.com> wrote:
> Is GDB available only for x86 architecture?
> Gedare Bloom wrote:
>> http://www.rtems.com/wiki/index.php?title=Special%3ASearch&search=eclipse&go
>> =Go
>> not much info on using gdb+eclipse specifically in RTEMS but I think
>> you can find that out other places once you have eclipse working.
>> On Thu, Apr 5, 2012 at 11:41 PM, Fered <a_Fered at yahoo.com> wrote:
>> > Hi Wendell;
>> > Thank you for your answer.
>> > It's a brief help. I need more explanation. Is it available manuals for
>> > eclipse integration and usage of gdb and eclipse for RTEMS?
>> > Regards.
>> > Wendell Silva wrote:
>> >> Hi Fered,
>> >> If your target has a serial port, you could make use of gdb glue-code
>> >> on
>> >> the target.
>> >> In the host side (eclipse) customize the debug properties to use
>> >> i386-rtems<version>-gdb.exe.
>> >> A detailed explanation on such a glue-code for gdb can be found:
>> >>    - rtems/c/src/lib/libbsp/i386/shared/comm/GDB.HOWTO.
>> >> Hope it helps.
>> >> --Wendell.
>> >> 2012/4/5 Fered <a_Fered at yahoo.com>
>> >> > Hi;
>> >> > How can I debug my RTEMS application for x86 target machine, on a
>> >> > linux host
>> >> > OS on a PC?
>> >> > I mean, is there a solution same as developing and debugging a C
>> >> > application
>> >> > on a linux using an IDE such as eclipse?
>> >> > Thanks.
>> >> > _______________________________________________
>> >> > rtems-devel mailing list
>> >> > rtems-devel at rtems.org
>> >> > http://www.rtems.org/mailman/listinfo/rtems-devel
