[PR 32] LEON3: fix open_eth interrupt initialziation bug
Tue Apr 10 19:16:17 UTC 2012
Applied. Close PR if OK.
On Tue, Apr 10, 2012 at 7:43 AM, Joel Sherrill
<joel.sherrill at oarcorp.com> wrote:
> This looks OK to apply.
> --joel
> Daniel Hellstrom <daniel at gaisler.com> wrote:
>>Fixed a bug where the vector number is used to clean and unmask
>>the IRQ at the IRQ controller, the irq number must be used.
>>Signed-off-by: Daniel Hellstrom <daniel at gaisler.com>
>> .../sparc/leon3/leon_open_eth/leon_open_eth.c      |    8 ++++----
>> 1 files changed, 4 insertions(+), 4 deletions(-)
>>diff --git a/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c b/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
>>index 3d42d9f..5799f83 100644
>>--- a/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
>>+++ b/c/src/lib/libbsp/sparc/leon3/leon_open_eth/leon_open_eth.c
>>@@ -47,7 +47,7 @@ int rtems_leon_open_eth_driver_attach(
>>       iobar = amba_ahb_get_membar(amba_conf.ahbslv, i, 0);
>>       base_addr = amba_iobar_start(LEON3_IO_AREA, iobar);
>>-      eth_irq = amba_irq(conf) + 0x10;
>>+      eth_irq = amba_irq(conf);
>>       device_found = 1;
>>       break;
>>@@ -61,14 +61,14 @@ int rtems_leon_open_eth_driver_attach(
>>     *(volatile int *) base_addr = 0x800;
>>     *(volatile int *) base_addr = 0;
>>     leon_open_eth_configuration.base_address = base_addr;
>>-    leon_open_eth_configuration.vector = eth_irq;
>>+    leon_open_eth_configuration.vector = eth_irq + 0x10;
>>     leon_open_eth_configuration.txd_count = TDA_COUNT;
>>     leon_open_eth_configuration.rxd_count = RDA_COUNT;
>>     /* enable 100 MHz operation only if cpu frequency >= 50 MHz */
>>     if (LEON3_Timer_Regs->scaler_reload >= 49) leon_open_eth_configuration.en100MHz = 1;
>>     if (rtems_open_eth_driver_attach( config, &leon_open_eth_configuration )) {
>>-      LEON_Clear_interrupt(leon_open_eth_configuration.vector);
>>-      LEON_Unmask_interrupt(leon_open_eth_configuration.vector);
>>+      LEON_Clear_interrupt(eth_irq);
>>+      LEON_Unmask_interrupt(eth_irq);
>>   return 0;
>>1.7.0.4
>>_______________________________________________
>>rtems-devel mailing list
>>rtems-devel at rtems.org
>>http://www.rtems.org/mailman/listinfo/rtems-devel
