[PATCH 1/3] score: Remove _Stack_Adjust_size()
Wed Apr 11 09:53:42 UTC 2012
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
The increase of the stack size by CPU_STACK_ALIGNMENT in
_Thread_Stack_Allocate() is disadvantageous. This may lead to a huge
over allocation for specialized stack allocators. The
CPU_STACK_ALIGNMENT is at most 16 on all current RTEMS CPU ports. The
mimimum stack size ensured by _Stack_Ensure_minimum() must be
considerable larger than this value, otherwise stack overflows will
likely occur. Thus the _Stack_Adjust_size() is also superfluous.
cpukit/score/inline/rtems/score/stack.inl | 18 ------------------
cpukit/score/src/threadstackallocate.c | 12 ------------
2 files changed, 0 insertions(+), 30 deletions(-)
diff --git a/cpukit/score/inline/rtems/score/stack.inl b/cpukit/score/inline/rtems/score/stack.inl
index c5d809c..2f49d01 100644
--- a/cpukit/score/inline/rtems/score/stack.inl
+++ b/cpukit/score/inline/rtems/score/stack.inl
@@ -24,7 +24,6 @@
#define _RTEMS_SCORE_STACK_INL
#include <rtems/score/basedefs.h> /* RTEMS_INLINE_ROUTINE */
-#include <rtems/score/cpu.h> /* CPU_STACK_ALIGNMENT */
* @addtogroup ScoreStack
@@ -90,23 +89,6 @@ RTEMS_INLINE_ROUTINE size_t _Stack_Ensure_minimum (
return _Stack_Minimum();
- * This function increases the stack size to ensure that the thread
- * has the desired amount of stack space after the initial stack
- * pointer is determined based on alignment restrictions.
- * @note
- * The amount of adjustment for alignment is CPU dependent.
-RTEMS_INLINE_ROUTINE uint32_t _Stack_Adjust_size (
- size_t size
- return size + CPU_STACK_ALIGNMENT;
#endif
diff --git a/cpukit/score/src/threadstackallocate.c b/cpukit/score/src/threadstackallocate.c
index 9448328..68aa649 100644
--- a/cpukit/score/src/threadstackallocate.c
+++ b/cpukit/score/src/threadstackallocate.c
@@ -51,18 +51,6 @@ size_t _Thread_Stack_Allocate(
the_stack_size = _Stack_Ensure_minimum( stack_size );
- * Pad the requested size so we allocate enough memory
- * so the context initialization can align it properly. The address
- * returned the workspace allocate must be directly stored in the
- * stack control block because it is later used in the free sequence.
- * Thus it is the responsibility of the CPU dependent code to
- * get and keep the stack adjust factor, the stack alignment, and
- * the context initialization sequence in sync.
- the_stack_size = _Stack_Adjust_size( the_stack_size );
stack_addr = (*stack_allocate_hook)( the_stack_size );
if ( !stack_addr )
1.7.1
