[rtems commit] score: New macros and functions
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Apr 11 14:03:36 UTC 2012
Can the rtems_ methods be at least referenced in the
configuring a system chapter with index entries?
I know that many aren't but there is no point adding
more to the "undocumented but intended to be public"
set.
--joel
On 04/11/2012 08:24 AM, Sebastian Huber wrote:
> Module: rtems
> Branch: master
> Commit: 5eb434e67ed31111eb90b92cf75248f2ff9d1086
> Changeset: http://git.rtems.org/rtems/commit/?id=5eb434e67ed31111eb90b92cf75248f2ff9d1086
> Author: Sebastian Huber<sebastian.huber at embedded-brains.de>
> Date: Wed Apr 11 15:04:22 2012 +0200
> New macros
> o _Objects_Maximum_per_allocation(),
> o rtems_resource_is_unlimited(), and
> o rtems_resource_maximum_per_allocation().
> New function
> o _Objects_Is_unlimited().
> cpukit/sapi/include/confdefs.h | 2 +-
> cpukit/sapi/include/rtems/config.h | 6 ++++++
> cpukit/score/inline/rtems/score/object.inl | 20 ++++++++++++++++++++
> cpukit/score/src/objectinitializeinformation.c | 7 +++----
> 4 files changed, 30 insertions(+), 5 deletions(-)
> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
> index ab8e473..d896c59 100644
> --- a/cpukit/sapi/include/confdefs.h
> +++ b/cpukit/sapi/include/confdefs.h
> @@ -954,7 +954,7 @@ rtems_fs_init_functions_t rtems_fs_init_helper =
> * for memory usage.
> #define _Configure_Max_Objects(_max) \
> - ((_max)& ~RTEMS_UNLIMITED_OBJECTS)
> + rtems_resource_maximum_per_allocation(_max)
> * This macro accounts for how memory for a set of configured objects is
> diff --git a/cpukit/sapi/include/rtems/config.h b/cpukit/sapi/include/rtems/config.h
> index 25ddfda..407b19e 100644
> --- a/cpukit/sapi/include/rtems/config.h
> +++ b/cpukit/sapi/include/rtems/config.h
> @@ -37,6 +37,12 @@ extern "C" {
> #define rtems_resource_unlimited(resource) \
> ( resource | RTEMS_UNLIMITED_OBJECTS )
> +#define rtems_resource_is_unlimited(resource) \
> + _Objects_Is_unlimited(resource)
> +#define rtems_resource_maximum_per_allocation(resource) \
> + _Objects_Maximum_per_allocation(resource)
> * This is kind of kludgy but it allows targets to totally ignore the
> * optional APIs like POSIX safely.
> diff --git a/cpukit/score/inline/rtems/score/object.inl b/cpukit/score/inline/rtems/score/object.inl
> index ac07e68..6a4fe21 100644
> --- a/cpukit/score/inline/rtems/score/object.inl
> +++ b/cpukit/score/inline/rtems/score/object.inl
> @@ -352,5 +352,25 @@ RTEMS_INLINE_ROUTINE void _Objects_Open_string(
> #endif
> + * Returns if the object maximum specifies unlimited objects.
> + * @param[in] maximum The object maximum specification.
> + * @retval true Unlimited objects are available.
> + * @retval false The object count is fixed.
> +RTEMS_INLINE_ROUTINE bool _Objects_Is_unlimited( uint32_t maximum )
> + return (maximum& OBJECTS_UNLIMITED_OBJECTS) != 0;
> + * We cannot use an inline function for this since it may be evaluated at
> + * compile time.
> +#define _Objects_Maximum_per_allocation( maximum ) \
> + ((Objects_Maximum) ((maximum)& ~OBJECTS_UNLIMITED_OBJECTS))
> #endif
> /* end of include file */
> diff --git a/cpukit/score/src/objectinitializeinformation.c b/cpukit/score/src/objectinitializeinformation.c
> index 01e1f96..4ddb11b 100644
> --- a/cpukit/score/src/objectinitializeinformation.c
> +++ b/cpukit/score/src/objectinitializeinformation.c
> @@ -62,7 +62,7 @@ void _Objects_Initialize_information(
> static Objects_Control *null_local_table = NULL;
> uint32_t minimum_index;
> - uint32_t maximum_per_allocation;
> + Objects_Maximum maximum_per_allocation;
> #if defined(RTEMS_MULTIPROCESSING)
> uint32_t index;
> #endif
> @@ -92,9 +92,8 @@ void _Objects_Initialize_information(
> * Are we operating in limited or unlimited (e.g. auto-extend) mode.
> - information->auto_extend =
> - (maximum& OBJECTS_UNLIMITED_OBJECTS) ? true : false;
> - maximum_per_allocation = maximum& ~OBJECTS_UNLIMITED_OBJECTS;
> + information->auto_extend = _Objects_Is_unlimited( maximum );
> + maximum_per_allocation = _Objects_Maximum_per_allocation( maximum );
> * Unlimited and maximum of zero is illogical.
> rtems-vc mailing list
> rtems-vc at rtems.org
> http://www.rtems.org/mailman/listinfo/rtems-vc
Joel Sherrill, Ph.D. Director of Research& Development
