[PATCH 3/4] libblock: Change error status to fatal error
Thu Apr 12 07:55:46 UTC 2012
On 04/12/2012 09:40 AM, Chris Johns wrote:
> On 12/04/12 5:27 PM, Sebastian Huber wrote:
>> We already have special fatal errors for the different lock/unlock
>> operations:
>> #define RTEMS_BLKDEV_FATAL_BDBUF_SYNC_LOCK RTEMS_BLKDEV_FATAL_ERROR(11)
>> #define RTEMS_BLKDEV_FATAL_BDBUF_SYNC_UNLOCK RTEMS_BLKDEV_FATAL_ERROR(12)
>> #define RTEMS_BLKDEV_FATAL_BDBUF_CACHE_LOCK RTEMS_BLKDEV_FATAL_ERROR(13)
>> #define RTEMS_BLKDEV_FATAL_BDBUF_CACHE_UNLOCK RTEMS_BLKDEV_FATAL_ERROR(14)
> Can the status code in rtems_bdbuf_lock be tested for RTEMS_UNSATISFIED and
> #define RTEMS_BLKDEV_FATAL_BDBUF_NO_INIT RTEMS_BLKDEV_FATAL_ERROR(xx)
> be raised ?
I added now some documentation and comments, see attached patch.
The only possible error returned should be RTEMS_INVALID_ID since we use
RTEMS_WAIT and RTEMS_NO_TIMEOUT.
Phone   : +49 89 18 90 80 79-6
Fax     : +49 89 18 90 80 79-9
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20120412/bdad2b47/attachment.bin>
