FIFO/Pipe Implementation
Sebastian Huber
Thu Apr 12 12:30:36 UTC 2012
Hello,
does anyone know why the FIFO/pipe implementation uses barriers for
synchronization? For me the usage of the barrier looks like a hand crafted
condition variable.
I think there is also a race condition in its use. The rtems_barrier_release()
releases only the threads currently waiting at the barrier. Now we have
several code sections like this:
PIPE_UNLOCK(pipe);
if (! PIPE_WRITEWAIT(pipe))
ret = -EINTR;
Thus the release may have no effect in case it happens after the PIPE_UNLOCK
and before the PIPE_WRITEWAIT (which is a rtems_barrier_wait() with no time out).
The bdbuf code uses a similar approach with semaphores. It disables the
preemption to avoid this race condition:
static void
rtems_bdbuf_anonymous_wait (rtems_bdbuf_waiters *waiters)
rtems_status_code sc;
rtems_mode prev_mode;
* Indicate we are waiting.
++waiters->count;
* Disable preemption then unlock the cache and block. There is no POSIX
* condition variable in the core API so this is a work around.
* The issue is a task could preempt after the cache is unlocked because it is
* blocking or just hits that window, and before this task has blocked on the
* semaphore. If the preempting task flushes the queue this task will not see
* the flush and may block for ever or until another transaction flushes this
* semaphore.
prev_mode = rtems_bdbuf_disable_preemption ();
* Unlock the cache, wait, and lock the cache when we return.
rtems_bdbuf_unlock_cache ();
sc = rtems_semaphore_obtain (waiters->sema, RTEMS_WAIT,
RTEMS_BDBUF_WAIT_TIMEOUT);
if (sc == RTEMS_TIMEOUT)
rtems_fatal_error_occurred (RTEMS_BLKDEV_FATAL_BDBUF_CACHE_WAIT_TO);
if (sc != RTEMS_UNSATISFIED)
rtems_fatal_error_occurred (RTEMS_BLKDEV_FATAL_BDBUF_CACHE_WAIT_2);
rtems_bdbuf_lock_cache ();
rtems_bdbuf_restore_preemption (prev_mode);
--waiters->count;
Please note that this approach is not SMP proof. I think we need condition
variables in the RTEMS Classic API.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
